Ecodan Zone 2 Mitsh...
Ecodan Zone 2 Mitshibishi thermostat Auto Adapt
5 Users
2 Reactions
(@ms13sp)
New Member Member
@majordennisbloodnok Good idea to add more points to the curve. I will definitely check out the ability to program offsets then.
 F1p
(@f1p)
Posted by: @ms13sp
With a bit of work you could probably create a template to take the difference between a room temperature sensor and target and adjust one the offset dynamically too (e.g. Manual)
You probably want to keep different to the Wind or Solar which could be dynamic from the weather forecast for example
Page 2 / 2
