Ecodan Cascade System Problem: DHW Heating Stops UFH & Pool Output
The issue seems to be solved: I found that the plumbers had routed the flow return from ASHP1 into the flow return of ASHP2, hence the whole system was behaving very badly.
I had to get the cascade removed to work it out, as there was only 1 set of thermistors - once the flow and returns of each ASHP could be monitored independently, it was pretty clear that there was a plumbing issue. Now the DHW ASHP is getting its proper flow return, the tank heating time has changed from not always being able to heat to target in 2hrs, to getting to 50 degrees in about 45 minutes!
I think the hardware supplier got the hump when asked to remove the cascade wiring (they took the master controller away...) so don't think I'll be asking for it to be put back in - with matching settings, the two ASHPs seem to be playing nicely, but the pool and pool room rads are not yet connected.
The next challenge will be getting 60mCu of water warmed up! - I assume for the initial heating, take the weather compensation off, fix both flow temps to perhaps 40 degrees and run it during the day to maximise efficiency.
Any thoughts on how long that volume of water would take to around 25 degrees?
- 807 Online
By Ubert767 , 55 minutes ago
By Renewables345 , 1 hour ago
By JamesPa , 1 hour ago
By Mars , 2 hours ago
By bobflux , 3 hours ago
By benson , 4 hours ago
By bobflux , 6 hours ago
By Jonatan , 11 hours ago
By Batpred , 18 hours ago
By Transparent , 21 hours ago
By bobflux , 22 hours ago
By Toodles , 1 day ago
