[Sticky] Heat Pump Books For Beginners – The Ultimate Guide to Heat Pumps, Bodge Buster & From Zero To Heat Pump Hero
Posted by: @travellingwave- but in fact I believe 90% of the value can be gained by just trending flow and return temps -
I use Home Assistant which captures the same data as that displayed in the Vaillant app (no additional hardware needed). OAT, FT and occasionally power consumption are all that's really needed 95% of the time. FT and OAT alone would probably suffice!
Also a good way to get data- I have had a play with the dongle that plugs into the Ecodan and integrates to home assistant.
All requires a certain level of tech savvy though. Heatpump should do this stuff out of the box.
Posted by: @travellingwaveHeatpump should do this stuff out of the box.
It has been said that both manufacturers and installers are reluctant to provide too much data too easily for fear of being overburdened with support calls.
I think I can understand this, whilst agreeing that it should be available one way or another. Better still of course would be if it weren't needed!
Currently viewing this topic 1 user ( Majordennisbloodnok ) and 2 guests.
Recently viewed by users: ASHP-BOBBA 50 minutes ago, Morgan 56 minutes ago, Mars 57 minutes ago, JamesPa 17 minutes ago.
- 2,505 Topics
- 58.1 K Posts
- 211 Online
- 6,237 Members
RE: Any thoughts on control strategies for heat pumps?
I imagine, given your background, you might have come a...
By JamesPa , 23 minutes ago
It has been said that both manufacturers and installers...
By JamesPa , 41 minutes ago
RE: New Solar, Batteries, Air Source and Under Floor Heating advice please
Good idea IMHO. You just need some appropriate time co...
By JamesPa , 2 hours ago
Hi all. I have made some progress regarding cause of cy...
By Tasos , 2 hours ago
My boiler had its service back in July last year (2025)...
By N1ckw , 2 hours ago
RE: Need some help with choosing the right Rads
Wow, thats a big (or very poorly insulated) bathroom. ...
By JamesPa , 3 hours ago
Monty Python may have asked 'what have the Romans ever ...
By cathodeRay , 4 hours ago
RE: Knock on effective of balancing radiators
Decorators caps, not screwed down (they can actually be...
By JamesPa , 5 hours ago
@craigh Hello, I had best explain how my Homely control...
By Toodles , 5 hours ago
The road to upgrading to the latest CU standard is ofte...
By Batpred , 18 hours ago
I'm not so sure that the rest of society values a maths...
By JamesPa , 19 hours ago
Thanks a lot GC61 - I'll open a separate thread in due ...
By Kev1964-IRL , 21 hours ago
RE: The Hidden Secret to a Successful Heat Pump: Pipe Size Matters
@falesh having a house of similar age the two issues I ...
By Terry1812 , 22 hours ago
RE: Our Experience installing a heat pump into a Grade 2 Listed stone house
Remember that the house continues to lose energy when t...
By JamesPa , 22 hours ago
@editor I'd missed that, and it's a very good response ...
By Sheriff Fatman , 1 day ago
There has been quite a bit of discussion (mostly on OEM...
By MartinRobinson , 1 day ago
@af1 My EPC rating jumped from E to C after installatio...
By dr_dongle , 1 day ago
@odd_lion the minimum MCS requirement is 2.8. I don't...
By benson , 1 day ago
RE: Advice on potential HW Cylinder size
I think the comment about heating from cold is quicker ...
By sjcsystems , 2 days ago
RE: Ideal HP290 14kW ASHP - how to optimise
Hi You can get a stethoscope for less than 10€ on Ama...
By bobflux , 2 days ago
Your DT is to low, you do not have enough heat exchange...
By ASHP-BOBBA , 2 days ago
I am aware. But is your chart direct from a Pace BMS ap...
RE: Call for heat on open loop weather comp system
I don't know Grant system but most ASHP are very simila...
@painter26 — good idea. Please do let us know what he s...
