When registering, please note that you will not be able to change your username. Please avoid using brand names in your forum username. While you may have arrived here seeking information on a specific product, the discussions on this platform cover a wide range of topics. As your interests evolve, a generic username will better reflect your participation across the community.
It is also very important that you read and understand the Forum Rules & Terms of Use before signing up.
Renewable Heating Hub Forums
Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators & Controls (1 viewing)
Wood Burners, Biomass, Small Scale, Biofuels & Other Heating Alternatives (1 viewing)
Well & Truly Off The Grid (1 viewing)
Buy & Sell
A place to buy and sell items relating to central heating, heat pumps and smart home tech. Feel free to advertise used or new equipment here. Renewable Heating Hub is not a shop and is not responsible for any defective products or warranty issues.
- 22 Forums
- 2,058 Topics
- 44.9 K Posts
- 33 Online
- 3,310 Members
RE: Advice for ground source heat pump in new build with PV and batteries
So is that with external air supply?
By Johnmo , 59 minutes ago
RE: Vaillant & OVO partner up to offer Heat Pump Plus
I moved from them a year or so ago, my monthly direct d...
By Johnmo , 2 hours ago
@arundalep yes I have no issue with this. The observati...
By benson , 2 hours ago
RE: Heat Pump Manufacturers Recommending Buffer Tanks
... but a volumiser would prolong run times by the same...
By JamesPa , 2 hours ago
@johnmo I have been looking at the daily Agile rates fo...
By Toodles , 5 hours ago
So your Halo lite should really do nothing, when connec...
By Johnmo , 6 hours ago
RE: Planning Update: 1 Metre Boundary Rule for Heat Pumps Has Been Scrapped
This is indeed welcome news. In addition the new legi...
By JamesPa , 15 hours ago
RE: IVT Greenline high pressure switch and electrical cassette errors
OK, so when the HP comes on it becomes obvious.It's on ...
By tdudgeon , 2 days ago
RE: Is Your 6kW Air Source Heat Pump Really a 6kW?
@johnmo I think we’ve been trudging through the same...
By SUNandAIR , 2 days ago
RE: How To Balance Radiators & the Role of the Lockshield Valve: A Homeowner's Guide
Good luck, I hope it all works out!
@johnd it's a difficult one, because we've seen instanc...
Win a 6-panel PV courtesy of egg and Renewable Heating Hub
Our epic giveaway just went live! Want to win a 6-pan...
RE: Yes, the "zoning with ASHP" topic again...
James, thanks again for your thoughtful and persistent ...
By HarryRea , 4 days ago
RE: Is this normal? Click of the DHW returning to space heating
So the Lone Ranger returned today! Even though we thoro...
My own experience with connecting four batteries to thr...
RE: Plate heat exchanger considerations
Work on 2-3 percent per degree. This is a reasonable e...
By JamesPa , 5 days ago
RE: Volumisers in Heat Pump Systems: Does Placement Matter?
You’re absolutely right that during defrost the refrige...
By Mars , 5 days ago
