Ecodan Pump Issues…...
Ecodan Pump Issues… Circulation pump turns off when heat pump compressor turns off
5 Users
9 Reactions
 F1p
(@f1p)
Posted by: @ashp-bobba
Posted by: @patch321
Just noticed this balancing valve on the flow pipe - do these come as standard?  Seems
odd since the recommended flow is 31 L/min and the maximum is goes upto is 28 L/min 🤨
20260114 181839
Sorry are you saying this is the return or flow to the ASHP external unit?
This is the 'OUTLET' from the external unit yes (so flow, before 3 way valve), as the magnetic filter is shown just below
This post was modified 2 hours ago 2 times by F1p
(@ashp-bobba)
Prominent Member Member Professional Installer
@f1p Perhaps they are not restricting and for some strange reason just installed it to read the flow rate?
Completely not needed and adds a bit of resistance for something covered by the controller
This post was modified 2 hours ago 2 times by ASHP-BOBBA
 F1p
(@f1p)
@f1p Perhaps they are not restricting and for some strange reason just installed it read the flow rate?
Throwing ideas out there, to protect pipework if they use a particularly large primary circulation pump on the 11.2's and someone does increase the speed?
I don't see anything about requiring it in the install manual and I haven't seen one installed before so agree that it doesn't really seem necessary
(@ashp-bobba)
@f1p I think it could me more there didn't realise the ASHP can indicate the flow when you are setting it up, where units do not have flow meters and were fixed speeds you would have to install an indicator but I think most brands now display the flow rate. I am trying to make stuff up to justify it 🙂
Page 4 / 4
