Recommended home battery inverters + regulatory matters - help requested
Posted by: @johnnyb@jamespa having read through this thread I will add a few comments that might help.
Fogstar now sell their 16.1kWh battery with fire suppression built in, might help any concerns over fire safety.
If you can find a local electrician who fits a lot of solar they would be able to do eveything you need and offer a lot of advice. The electrician who fitted our PV panels and inverter didn't wire the rest of the house but I wish I had used him for everything as he would have kept things more compact around the CUs and offered better advice on what to fit and how to set it up. When I was trying to find a company for the PV panels I found several small solar companies local to me that are run by electricians who don't only fit solar panels. He did say I would need an earth stake, but we already had one fitted.
Thanks. The frogstar is the one Im potentially looking at.
I do know a good electrician but I dont think he does solar. Whenever I have contacted solar companies in the past they seem to be rather specialist, which is why I have been thinking of going down the route of general electrician and asking him to do the inverter stuff. However your suggestion is very helpful, whilst the individual companies might be specialist the electricians they employ may not be so I will also explore that route thanks.
If its going to happen at all its all going to happen all at once, firstly because its the only way it has any chance of making the business case for the battery work and secondly because I don't want a mess of sub CUs. Its either (Battery inverter + EV Charger + circuit for Induction Hob + redo CU) or nothing as far as I am concerned. Nothing remains a distinct possibility; none of this is absolutely necessary for me, I dont have to have a battery, I can continue charging my EV on a granny charger and we may never swap out gas hob for an induction hob (even though we are paying the whole standing charge just to run the hob) as we attach some value to fuel diversity. That said ~£500-600 saving annually for an investment which hopefully is ~ £K5-6 is quite attractive.
Could you just get the electrician to fit the new circuit in your CU for the battery storage to and including the rotary isolator switch, which any electrician would be happy to do.
You can then just isolate that circuit and install the inverter and batteries yourself?
That would avoid the need for a "solar specialist" who will almost certainly charge you plenty for the pleasure.
Currently viewing this topic 3 users ( TechnoGeek, Bash, trebor12345 ) and 5 guests.
Recently viewed by users: Transparent 50 seconds ago.
- 2,418 Topics
- 54.8 K Posts
- 379 Online
- 6,098 Members
@jamespa BTW induction hobs are fantastic and well w...
By Bash , 6 minutes ago
RE: Is it normal to use power from the grid when running off the battery?
Yes, you will have some import unfortunately. The inv...
By Bash , 9 minutes ago
@robs — thank you for such a detailed interesting and i...
By cathodeRay , 34 minutes ago
R290 and Foundation Air Bricks
I am going around in circles. My property has foundatio...
By L8Again , 1 hour ago
RE: Installer Fitted 9kW Instead of 11kW Heat Pump and Changed MCS Paperwork - What do I do?
Another good bout of cold weather should test whether t...
By JamesPa , 2 hours ago
RE: How to use my Hanchu battery storage for home without it feeding back into the grid?
Mine is the same as @skd i have luxpower inverters and ...
By IRMartini , 2 hours ago
RE: Ecodan Pump Issues… Circulation pump turns off when heat pump compressor turns off
@ashp-bobba I agree. I think I'll simplify the system j...
By Patch321 , 5 hours ago
RE: Reliable, easy to use home battery options
I have just had a my inverter and battery installed, ab...
By JohnnyB , 11 hours ago
RE: Samsung E101 Error Message and my ASHP Efficiency
@johnnyb amazing that the our forum is serving its purp...
By Mars , 13 hours ago
Best option for controller upgrade? - Grant Aerona
Fairly new heat pump owner - Grant Aerona 3 10kw - and ...
By Topher , 14 hours ago
RE: Daikin Wireless Thermostat
@toodles Yes. British Gas seems to have done an exce...
By Bash , 15 hours ago
RE: Is my Samsung gen6 outside air temp sensor missing a sheath/sleeve?
@papahuhu Mine is similar. Is your house not getting...
By bontwoody , 17 hours ago
Just a brief update to keep things transparent. Secti...
By DREI , 18 hours ago
RE: Ideal HP290 14kW ASHP - how to optimise
Sorry forgot about the three choices. It’s the 2nd one ...
By Davesoa , 19 hours ago
I continue to receive emails from homeowners sharing he...
By Mars , 19 hours ago
RE: Water outage in the the south-east
We think alike @editor ! All those bottles (and I expec...
By Toodles , 19 hours ago
@mrfield, welcome to the forums. Please go here and ...
By Mars , 22 hours ago
I did not hear back from the tech team. (Assume they ar...
By swwils , 23 hours ago
In the Home Assistant firmware the data points...
RE: GSHP WOES! Midland based engineer recommendations?
@johnbroome if it is not the pressure in the expansion ...
By ASHP-BOBBA , 2 days ago
