Biocide and Inhibitor
Hi all
I’m looking to get some insight on what others are using for biocide and inhibitor in air source heat pump systems. I am focused mainly on systems with AFV's, but could also do with some advice on glycol filled system too.
At the moment, we use R700 and X100, but we’ve seen some concerning press recently regarding these products. I’m particularly interested in:
- What products you trust for preventing microbial growth in ASHP systems.
- Recommendations for treating systems that already have spores or microbial contamination.
- Best practices for preventing these issues from occurring in the first place.
Any advice, product recommendations, or experience you’ve had would be really appreciated!
Thanks in advance.
Can you specify what the 'concerning press' is? It may just be typical media scaremongering.
It is also a good idea to spell out what an abbreviation stands for the first time you use it. AFV? Armoured fighting vehicle? If so, that's a bit over the top for harmless bacteria.
@cathoderay I took it to mean Anti-Freeze Valve.🤨 Regards, Toodles.
Posted by: @toodlesI took it to mean Anti-Freeze Valve
Possibly, given the context, but we don't know for sure. IDDAH to spell things out (it doesn't do any harm).
Posted by: @cathoderayCan you specify what the 'concerning press' is? It may just be typical media scaremongering.
I saw some chatter last year about general environmental impacts of biocides/inhibitors (potential for runoff or long-term aquatic effects if not handled properly when systems are flushed).
One school of thought says put almost nothing in and instead treat only to VDI2035 which is a German standard. So far as I can see there is a lot to be said for this approach. My cynical side says that, just like smart external controls, the industry may have developed and promoted products we don't need and never needed.
@jamespa I share your cynicism. I do suspect there’s a place for biocide I systems, but fully agree that VDI should be a far greater consideration.
@cathoderay It is meant to be Anti-Freeze Valves. When I say concerning it is a bit of an exaggeration, but it is more to say that it isn't adding benefit to the system, and rather causing issue with these "spores". We've seen a lot of systems with strainers filled to the brim with them, and we can't seem to find a strong solution to stop this from happening.
@renewables345 — thank you for the clarification. I'm rather aligned with @jamespa and @editor on this, the biocide products are more likely to be be solutions (sic) in search of a problem than anything useful. Inhibitors on the other hand probably do serve a useful purpose.
You can't normally see 'spores' unless they have somehow grown into something macroscopic. Has anyone looked at the debris in the filters under a microscope?
Passiv Smart Thermostat - Help & Forum Support
2 weeks ago
Considering MLCP (Multi-Layer Composite Pipe) for ASHP
2 months ago
Smart or not?
4 years ago
- 819 Online
By bobflux , 6 minutes ago
Welcome to the forums. You are in an interesting posi...
By JamesPa , 7 minutes ago
By bobflux , 1 hour ago
By Jonatan , 5 hours ago
By bobflux , 12 hours ago
By Batpred , 13 hours ago
By Transparent , 16 hours ago
By bobflux , 17 hours ago
By Toodles , 19 hours ago
By JamesPa , 23 hours ago
By Toodles , 4 days ago
