Free Ecoheat Heat Pump Install
Posted by: @bontwoody@deltona A diy install isnt as scary as it sounds. Its not rocket science and there is a lot if good info out there. Check out glyn hudsons videos on youtube. That was my starting point. 😁
@deltona No worries. The air change issue is a well know error and easy enough to correct for.
Sounds like a plan to fit pipework etc with a heatpump in mind for later
Posted by: @bontwoody@deltona No worries. The air change issue is a well know error and easy enough to correct for.
Can you explain more, or point me in the direction where I can research it? Initially I had assumed i'd have to do my own test to be accurate.
It seems to me that you have to test it to be sure as nothing or nobody can assume what my house is. It's a bit like the solid, rubble filled walls, because nobody knows how well they were built (therefore what they contain, muck, voids, etc) it's just guesswork as what the U value is.
@deltona Yes older houses are problematic like that, but the standard air change assumption figure is know to be on the very high side and often leads to over sized heat pumps being fitted particularly in newer houses.
If you are fitting a lot of insulation and double glazed windows that should reduce air changes greatly. The core of my house is 1840s stone walls and we have no problems heating it with a 5kW Heat pump after our renovations.
- 409 Online
By Ubert767 , 27 minutes ago
By Renewables345 , 49 minutes ago
By JamesPa , 56 minutes ago
By Mars , 2 hours ago
By bobflux , 2 hours ago
By benson , 4 hours ago
By bobflux , 5 hours ago
By Jonatan , 10 hours ago
By Batpred , 18 hours ago
By Transparent , 21 hours ago
By bobflux , 21 hours ago
By Toodles , 1 day ago
