@derek-m, so true. We’ve seen scores of members here tag teamed into submission and exhaustion.
Follow our sustainability journey at My Home Farm: https://myhomefarm.co.uk
Thanks for your offer of advice ,Derek.
How NOT to set up a Heat Pump!
After enduring a shouting match between myself , two Engineers from my "installer" and a NIC Engineer, My confidence in the NIC and my installers has been destroyed.
The Two Installer Engineers left my Heat Pump inoperative after demonstrating how not to set up a Heat Pump, followed by an hour long failure to repair the resulting fault. terminating with a swift, silent exit.
The NIC Engineer departed after suddenly deciding that "he needed some air" , leaving myself to undo the set up errors.
A Devastating example of how not to inspire confidence in either my "installer" or the NIC.
The NIC now says that "nothing can be done" and that I should seek legal advice and / or advice from Citizens Advice or Conciliation and Arbitration.
Following the "success" of their MCS,NICEIC ,RECC organisation of the renewable industry I now read that the UK Government is proposing to extend "Light Touch Regulation ", LTR to the implementation of Artificial Intelligence, AI !
That "Light Touch Regulation" has been reduced to a three letter mnemonic, LTR, leaves me cold , literally cold, and speechless .
Nothing has been learnt from the MCS, NICEIC, RECC fiasco!
I have now resigned myself to repairing and or replacing my heat pump myself.
After, eighteen months of "Light touch Regulation " costing me circa £5.6 K I am left repaying a "loan" of £2.2K on a system with Energy losses between 23% and 48%( HOT Water) with a REAL- Winter COP of 2.01 that has a (short) cycling time of 11 minutes over a run time of 5 minutes.
The NIC,cMCS say that " You are not going to like this ... but, nothing can be done when your "installer" is "sanctioned, and STRUCK OFF."
The NIC now say that "they have extended their sanctions against my installer". Useless!
@Derek--m
With my "installer" being STRUCK OFF for the third, and hopefully final time, I will have to repair and replace my heat pump myself.
I intend with some trepidation, removing the lousy heat exchanger, an unnecessary 200 litre hot water tank and a 50 litre buffer tank.
I will also remove the water valves switching water between the Hot Water Tank and the heat exchanger.
I will also replace a faulty Samsung controller board, hopefully allowing the pulse width modulation motor output to finally work.
How to start, I am full of trepidation... Given my inexperience and the sheer physical size and weight of the heat pump .
@iantelescope, that is a daunting prospect and I wish you all the best, and it's simply ridiculous that you have found yourself in this situation.
Please feel free to start a new dedicated topic relating to the work you intend to undertake and we'd all love to follow the progress.
@iantelescope thank you for sharing your saga with us. I have forwarded this onto the MCS and NICEIC for comment.
https://renewableheatinghub.co.uk/left-out-in-the-cold-homeowner-abandoned-by-mcs-nic
@iantelescope and @west - as the most recent members with fresh cases and issues, do either of you have home insurance with a additional legal cover?
Yes have legal cover been there tried that, thanks anyway, they all say take legal action, dead end when no funds left to take action, government in Scotland no help, block you at every turn, even the green party net zero MSP!
The Samsung pulse width modulation output does not work at flow temperatures below 45 Deg C, why? It is anybody’s guess.Posted by: @iantelescope@Derek--m
Professional heat pump installer: Technical Director Ultimate Renewables Director at Heacol Ltd
@west I’m very curious to hear about your legal process and why that failed.
I've been looking into this subject but can't find a definitive answer. Maybe someone can point me in the right direction. The MCS claims to provide a framework for ensuring the quality of both the installation work and the products used in heat pump installations in the UK. In MCS's own words, "An MCS certificate is proof that your installation has been designed, installed & commissioned to the highest standard using only MCS certified products by an MCS certified installer." That's not really saying an awful lot is it?
Does anyone know what the MCS's parameters, standards or definitions are for a "high standard" installation?
@editor Maybe somewhere from this link Mars
https://mcscertified.com/skills-and-competency/
Regards, Toodles.
Toodles, 76 years young and hoping to see 100 and make some ROI on my renewable energy investment!
Mid terrace - ASHP Install location
2 months ago
Any installer recommendations for Samsung ASHP?
3 months ago
Ecodan - optimal external installation?
3 months ago
Does your heat pump calculate and provide you with a COP figure?
5 months ago
Any recommendations for ASHP installers in the North West?
11 months ago
- 25 Forums
- 1,442 Topics
- 30.2 K Posts
- 16 Online
- 1,225 Members
Yes, it is one of those two who first alerted me to the...
By IvanOpinion , 12 hours ago
RE: EV charger installation question – I don't want to bury the cable
The fact that the MCB is rated 16A tells us what we nee...
By Transparent , 12 hours ago
RE: Are You Getting the Most Out of Your Renewable Energy?
Thanks, @editor. Ideally it’d be someone who would li...
By Majordennisbloodnok , 14 hours ago
Unless adequately controlled it could devour your bank ...
By Derek M , 15 hours ago
RE: Effect of buffer tank or volumiser on heat pump system
I think that you will find that the best location for a...
RE: ASHP Commissioning: What Questions Should I Ask the Installer?
@derek-m thanks - will look out for the point regarding...
By Declan90 , 1 day ago
RE: Noise problems with newly installed Samsung 8kW ASHP
@editor @kenbone Thanks, I would be very interested ...
By Elton , 1 day ago
This is all a bit too frequentist for my liking. The pr...
By scrchngwsl , 1 day ago
Relax with 4K drone footage of lawn mowing to a smooth Motown tune
Sending out some chilled weekend vibes to everyone. Lis...
RE: Incorrect Billing of Customers with a Smart Meter
The starting point of that discussion on Camelot-Forum ...
Share Your Experiences with Heat Pump Manufacturer Support
Have you ever reached out to your air source heat pump ...
RE: Is this a bad installation and is there something wrong with my Samsung heat pump?
@ant87 thanks for that.
By David999 , 3 days ago
I might change my mind again, but I'm currently unlikel...
By IvanOpinion , 3 days ago
RE: Samsung ASHP scheduling help
@elgreco69 worth reading the GitHub here as that will a...
By morh , 3 days ago
RE: ASHP sizing - value of Heat Transfer Coefficient
@toodles Thanks for the explanation I get it now as I h...
By Jancold , 3 days ago
RE: Questions about yearly heat pump maintenance
For the installer, I believe servicing and maintenance ...
@retrorich It is very worrying that any of this should ...
By Toodles , 4 days ago
RE: Spacing for roof fixing bolts ?
There is another consideration...but alas this doesn't ...
RE: Air source heat pumps and noise
Yes, but when they go wrong things get really sticky. D...
Heat Pump Humour
Latest Topics
By David999 11 hours ago
By heat-pump-newbie 6 days ago
By jamesw 7 days ago
By KoRWraith 1 week ago
Home energy storage & battery register
By Mars 1 week ago
