Need some help with choosing the right Rads
Hi all,
I've got an installation coming up of a Warmflow Unit, and I am having some trouble with the radiators for the bathroom.
The heat loss is around 1.9kW. I plan to have one electric towel rad and a standard central heating rad. Does anyone have any recommendations?
Thanks in advance
Posted by: @renewables345Hi all,
Thanks in advance
Wow, thats a big (or very poorly insulated) bathroom. Are you sure its that much?
As I'm sure you know radiator output and thus selection depends on the design flow temperature so without that its impossible to say. For example a radiator that is rated at 1kW at the standard 50C difference between rad and room (eg flow temp 75, return 65), will emit only 360W at a more typical heat pump flow temp of 45 and return temp 40.
Whats your design FT? You may struggle to find a radiator, other than a large type 33, that will do 1.9kW at 45. I had a similar requirement in my lounge area and ended up with a (very satisfactory) fancoil because a passive radiator with that capacity just wouldn't fit.
- 2,505 Topics
- 58.1 K Posts
- 304 Online
- 6,237 Members
@jamespa Also a good way to get data- I have had a p...
By Travellingwave , 28 minutes ago
RE: New Solar, Batteries, Air Source and Under Floor Heating advice please
Good idea IMHO. You just need some appropriate time co...
By JamesPa , 34 minutes ago
Hi all. I have made some progress regarding cause of cy...
By Tasos , 36 minutes ago
My boiler had its service back in July last year (2025)...
By N1ckw , 54 minutes ago
RE: Need some help with choosing the right Rads
Wow, thats a big (or very poorly insulated) bathroom. ...
By JamesPa , 2 hours ago
Monty Python may have asked 'what have the Romans ever ...
By cathodeRay , 3 hours ago
RE: Knock on effective of balancing radiators
Decorators caps, not screwed down (they can actually be...
By JamesPa , 4 hours ago
@craigh Hello, I had best explain how my Homely control...
By Toodles , 4 hours ago
The road to upgrading to the latest CU standard is ofte...
By Batpred , 16 hours ago
I'm not so sure that the rest of society values a maths...
By JamesPa , 18 hours ago
Thanks a lot GC61 - I'll open a separate thread in due ...
By Kev1964-IRL , 20 hours ago
RE: The Hidden Secret to a Successful Heat Pump: Pipe Size Matters
@falesh having a house of similar age the two issues I ...
By Terry1812 , 21 hours ago
RE: Our Experience installing a heat pump into a Grade 2 Listed stone house
Remember that the house continues to lose energy when t...
By JamesPa , 21 hours ago
@editor I'd missed that, and it's a very good response ...
By Sheriff Fatman , 24 hours ago
There has been quite a bit of discussion (mostly on OEM...
By MartinRobinson , 1 day ago
@af1 My EPC rating jumped from E to C after installatio...
By dr_dongle , 1 day ago
@odd_lion the minimum MCS requirement is 2.8. I don't...
By benson , 1 day ago
RE: Advice on potential HW Cylinder size
I think the comment about heating from cold is quicker ...
By sjcsystems , 2 days ago
RE: Ideal HP290 14kW ASHP - how to optimise
Hi You can get a stethoscope for less than 10€ on Ama...
By bobflux , 2 days ago
Your DT is to low, you do not have enough heat exchange...
By ASHP-BOBBA , 2 days ago
I am aware. But is your chart direct from a Pace BMS ap...
RE: Call for heat on open loop weather comp system
I don't know Grant system but most ASHP are very simila...
@painter26 — good idea. Please do let us know what he s...
Yes, but I need to reopen the battery box.. I just noti...
