This particular example is one of the worst I have seen here. Uninsulated buried primaries!, uninsulated pipework around the cylinder, system separation, oversized heat pump, undersized radiators and doubtless some things we don't know about because they are masked.
The plumber who 'installed' this should be struck off! It's almost like they designed it not to work, but I doubt they were that competent. The lack of insulation would be equally bad if this were a boiler installation (worse in the case if the dhw tank, because it would be heated to a higher temperature), how were they ever let near this job. It makes one wonder about the rest of the plumbing.
5 days ago
Ecodan Zone 2 Mitshibishi thermostat Auto Adapt
1 month ago
Ecodan Pump Issues… Circulation pump turns off when heat pump compressor turns off
2 months ago
2 months ago
New Mitsubishi Ecodan 11.2kW installation - L9 errors and maybe more
2 months ago
- 439 Online
By bobflux , 15 minutes ago
By Renewables345 , 1 hour ago
By benson , 2 hours ago
By cathodeRay , 3 hours ago
By bobflux , 3 hours ago
By bobflux , 4 hours ago
By Jonatan , 8 hours ago
By bobflux , 15 hours ago
By Batpred , 15 hours ago
By Transparent , 19 hours ago
By bobflux , 19 hours ago
By Toodles , 22 hours ago
