Indevolt Batteries ...
Indevolt Batteries UK Support & Info Thread
23 Users
121 Reactions
77.2 K Views
(@blizzardgreen)
Posted by: @transparent
Posted by: @blizzardgreen
My ideal install would have my battery installed before the CU and have my cu wired to the back up socket.
There are electricians who would be prepared to implement such a strategy...
... but not if the Loads could exceed the 400w available.
AC changeoverMCB
Is it not 3KW?
Your energy: 73 kWh
Is it not 3KW?
As I recall, 3kW is the maximum available from the maintained outlet if you've bought sufficient add-on battery packs.
I'd need to check the specs again to know what level Indevolt will limit the output to if you have just the basic box, with & without a 'charge from the grid' option.
(@blizzardgreen)
Is it not 3KW?
I had a quick look and they are a little vague.
They say with just the base unit, it's 1 kw. and 3kw with extra batteries, doesn't say how many.
Hopefully it gives half of the battery rating which would be 3 with one extra battery.
Edit to add AI says adding one battery gives 3kw ups.
So take that for exactly what it's worth. 🙂
This post was modified 4 months ago by BlizzardGreen
(@dansus)
Posted by: @indevolt-tech
Standard G98 & BS 7671 Fixed Installation Route:
For users wishing to utilize the 800W grid feed-in / battery storage / peak-shaving capabilities, the PowerFlex 3000 must be installed via a fixed AC connection (e.g., dedicated switched fused spur or AC distribution board circuit) by a qualified electrician under traditional BS 7671 guidelines and registered via standard ENA G98 notification. It cannot rely on the simple plug-in route.
Hi, can you remind me how to enable 3kW feed in when grid tied, do we need base unit plus two batteries?
Your energy: 115 kWh
2. Standard G98 & BS 7671 Fixed Installation Route:
@indevolt-tech  When you say 'dedicated switched fused spur' is that a dedicated spur of a ring main (ie on the load side of the CU) as suggested by your text.
I had understood that microgenerators had to be on an AC distribution board circuit on the supply side, but maybe there is a carve out for sub-800W microgenerators, even those with batteries, that allows them to be installed on a load-side spur.  Please can you quote the actual regulation that you are relying on.
Indevolt Tech
(@indevolt-tech)
@jamespa For any battery storage or microgeneration system operating in parallel with the grid (under ENA G98 and BS 7671 Regulation 551.7 regarding low-voltage generating sets): The primary, standard compliance route is a dedicated circuit wired directly to the Consumer Unit (CU), protected by a dedicated bi-directional RCD/RCBO and an adjacent switched isolation point.
Where a "fused connection unit / switched spur" is mentioned in our practical setup discussions, it refers to the local switched isolation point / lockable isolator required near the equipment for safe maintenance, rather than tapping arbitrarily into a heavily loaded general ring main.
Because cable rating, protective device coordination (BS 7671 Section 433/434), and RCD selection (Type A/F/B depending on inverter leakage characteristics) vary per property, the exact circuit design must be determined and signed off by a certified electrician.
⚡ Indevolt UK Technical Team
Official Support | Smart Energy Storage & Home Automation Solutions
🛠️ Discord: https://discord.gg/aZTvvTK9pt
📧 Support: support.uk@indevolt.com
Indevolt Tech
(@indevolt-tech)
We have noticed a few queries across our UK community regarding grid certifications (G98, G100 and G99). We want to provide complete transparency regarding our compliance timeline and system specifications:
📜 1. Certification Timeline Update (G98 & G100)
Our official G98 and G100 certification testing and documentation are progressing as scheduled. We expect to have the official certificates fully issued by around 20th August 2026.
Once issued, all certified type-test documentation will be published directly on our official website for easy reference during your installation and DNO notification process.
🔌 2. Why G98 Meets All Installation Requirements (No G99 Required)
Under ENA (Energy Networks Association) guidelines in the UK:
  • G98 Standard: Applies to micro-generation and storage systems with a total AC output capacity of up to 16A per phase (3.68kW / 3680W).
  • G99 Standard: Applies strictly to larger installations exceeding 3.68kW per phase, requiring prior DNO approval and complex network studies.
Because the maximum AC feed-in capacity across our PowerFlex 3000 Series is designed below 3.68kW (under 3680W), the G98 simplified notification route fully covers all legal and installation requirements for UK homes.
You do not need a G99 application to install and operate our systems legally in parallel with the National Grid—saving you from unnecessary administrative hassle and DNO approval delays!
🛡️ 3. Integrated G100 Export Limitation
To give UK homeowners complete peace of mind, our G100 certification ensures built-in, failsafe export limitation controls. This guarantees that your setup seamlessly manages power flow and respects local network feed-in limits under all operating conditions.
Thank you for your continued support as we finalise these certifications to bring fully compliant, smart home energy storage to the UK market!
Feel free to drop any questions below or reach out to our team at support.eu@indevolt.com.
Indevolt Tech
(@indevolt-tech)
@jamespa Hello, to guarantee 100% compliance across all UK Distribution Network Operators (DNOs) and home insurance policies, the primary and most robust compliance route is a dedicated AC circuit wired back to the Consumer Unit (CU), protected by a dedicated bi-directional RCD/RCBO, with a local Switched Fused Spur/Isolator placed next to the unit for safe maintenance.
While an 800W or 3kW inverter connected via a Fused Spur on an existing ring main is technically simple, BS 7671 requires that any parallel generation source does not risk overloading ring circuit conductors (Section 433/434). Therefore, while some qualified electricians may assess a lightly loaded ring circuit and sign it off under Part P, Indevolt officially recommends a dedicated CU circuit to avoid any ambiguity during DNO G98 registration.
Under existing ENA G98 rules, any battery system capable of grid discharge—whether throttled to 800W or operating at full 3.68kW—is classed as a grid-tied energy storage system. There is currently no special exemption under BS 7671 that treats an 800W battery discharge differently from a 3kW battery discharge when connected to home wiring. Both require standard G98 notification and BS 7671 compliance.
To use the Indevolt system legally for grid feed-in / dynamic tariff arbitrage in the UK today:
1. Who: A qualified, Part P-registered electrician.
2. What: Install a dedicated AC circuit (or assess/install a local switched isolator/fused spur) according to BS 7671.
3. Grid Registration: The electrician submits a standard ENA G98 notification (which is Free of Charge) to your local DNO within 28 days of commissioning, using our official G98 Type-Test Certificate (being issued around Aug 20th).
We are currently updating our website (uk.indevolt.com) to include a dedicated "UK Installation & Wiring Pathways Guide" so this exact technical information is completely transparent for all buyers.
Thank you for pushing for this level of detail—this is precisely the clarity the UK market needs. 🙂
@indevolt-tech thanks that's most helpful.
Hopefully plug in batteries will relatively soon become fully legal!
Personally I fully understand and support the route government has taken, given the quite extraordinary efforts that the installation industry has gone to in an attempt to block plug in altogether. Nevertheless it's very frustrating as a householder (and doubtless even more frustrating as a manufacturer!).
Your energy: 73 kWh
G99 also applies when there is more than one G98 appliance being installed at the same dwelling.
Thus if I were to have a solar-inverter and a storage battery, each capable of export to the grid, then I would complete the online form for G99FT (Fast Track). This is available on the website for your DNO.
This is another minor hurdle which DESNZ needs to address. There are going to be domestic premises which would reasonably like to have two plug-in solar kits, plus an Indevolt battery.
G99 has four Types, which go all the way up to a full power station. Here we are discussing G99 Type-A, which is "below 1MW". See NESO G99 specification document (PDF).
Indevolt Tech
(@indevolt-tech)
@transparent Thanks for adding this level of accuracy to the thread.
(@dansus)
Posted by: @dansus
Not interested in a plug in device, or 800w. Just need to know from a hardware standpoint, what system config do I need to make sure I can feed in 3kW from this unit if i purchase it @indevolt-tech
Obviously, it will be installed by a qualified solar electrician, and G98 submitted.
This post was modified 4 months ago 7 times by dansus
Page 25 / 29
