That's all good news @eliuccio
... and extra thanks for posting here the photo of the trips with blue levers on the side of the Growatt ARK Battery Control Unit.
I'm pleased to note that the Cahill engineer has taken the trouble to actually explain a number of points,
rather than just switching the battery back on. 😀
His observation that the battery system is "isolated" matches what I had expected.
The word isolated can mean two different things in this situation.
What he (and I) mean here is that the battery 52v cabling is 'floating' and not tied to earth or anything else.
That's how it should be...
... and that's why my own batteries don't have the connections covered.
I can't get an electric shock by touching them, and nor can you.
I can think of two possible reasons why the battery trips went off.
The one which is most relevant is that there might've been a lightning strike nearby (within a couple of miles).
Sometimes trips pick up the passing spike and switch off.
No harm done.
Good news with having the RCBO changed for a bi-directional one.
That provides confidence that the safety protection will actually work if it needs to!
Whatever UKPN say about the Service Fuse upgrade from 60A, please let us know.
If they insist on a move to 3-phase, please don't be daunted.
We can help to explain what's involved both during and after that upgrade.
It would mean you'd have your Smart Meter changed too.
That's fine.
I'm a Smart Meter specialist and I can answer whatever you'd like to know.
An upgrade to 3-phase under these circumstances shouldn't require you to pay anything.
You will, however, be asked to divide the household circuits across more than one phase.
We have photos of your consumer units here, and I already have an idea how to achieve what's required at minimal cost for the electrician's time.
Let's wait and see what UKPN say first.
@transparent there is big difference in LV vs HV for DC circuits compared AC.
A 9v PP3 battery will kill you if you are daft enough to put your tongue on it.
There are cases where children have swallowed button cells and not survived, they are 3.3V
Posted by: @agentgeorge...
The same has been claimed of my sister-in-law's cooking, although in fairness that's more a case of salt and buttery.
OK, taxi's ordered.
@majordennisbloodnok Straight to the cells with you!
@agentgeorge if you'd like to start a new topic on the dangers of AC/DC electricity, please do so.
Tag me there and I'll contribute.
It is an important issue, and relevant for this forum.
But I don't think other readers will find it here on p.4 of a topic which is about a particular Home Battery Storage problem.
PS... and I do test PP3 batteries by touching them to my tongue! 😲
@transparent Who needs a test meter?!😉
Need to put a warming on this thread incase anyone is following it… If it’s a discharged pp3 you'll get a tizzy tongue, don't try it with a fresh one.
It is all getting ticklish...
And phased with all of this. Anyone seeding for a any solar farm anywhere? 😀
16kWh Seplos Fogstar battery; 8kW Solis S6-EH1P8K-L-PLUS hybrid inverter; Ohme Home Pro EV charger; 100Amp head, HA lab on mini PC
@agentgeorge That’s a ittle too inscrotumable for me… Toodles.
@toodles As we have had the topic issue resolved, we can edge off track a bit, and do a bit of testiculating; that’s wandering around a solar farm, waving ones hands in the air and talking bollox
- 2,396 Topics
- 54.3 K Posts
- 151 Online
- 6,077 Members
The diagram below is a simplified view of the internals...
By Batpred , 5 hours ago
RE: Heat pump not reaching flow temperature
@davec Ive had a look at the screenshots. Lots of th...
By JamesPa , 5 hours ago
RE: Vaillant aroTherm not heating with many faults
When I had a series of apparently unrelated faults my i...
RE: Considering MLCP (Multi-Layer Composite Pipe) for ASHP
OK, TBH I dont know enough about MLCP to comment with a...
By JamesPa , 8 hours ago
RE: Predicted Heat Loss from MCS calcs vs EPC vs actual
My gut feeling is that the heat pump is right sized. ...
By Tim441 , 9 hours ago
RE: Power outages and storms: A surprisingly good DNO experience
Agreed, which is no more nor less than a customer shoul...
@batpred In our case, 3 times each day when the Octopus...
By Toodles , 11 hours ago
Hi @sheriff-fatman Cycling at 5C and below is usuall...
By RobS , 11 hours ago
@batpred Here's the latest Fogstar ready built pack....
By Bash , 12 hours ago
@mike-patrick yes, even though the current system is ru...
By Tim441 , 13 hours ago
Solis confirmed that the S6 works with a single battery...
By Batpred , 13 hours ago
I am wondering if in any V2X, would the car battery eve...
By Batpred , 14 hours ago
Yes, by calculating it manually from the minute data, w...
By cathodeRay , 15 hours ago
Fan unit Making terrible noise HELP!!
One of a pair of fan units on an Earth Save Classic II ...
By GutoFfowc , 15 hours ago
OK. I think your system, which seems well designed, is...
By JamesPa , 17 hours ago
RE: Heatpunk Floor plan issues
It's usually the complete opposite... seldom that Safar...
RE: Fan is clipping ice build up from the front of unit.
@majordennisbloodnok I’ll not go there thanks! Toodles.
By Toodles , 1 day ago
RE: Running my new Nibe ASHP efficiently
I'm new to the forum. Did you get a reply to this last ...
By Mike @ Camelot , 1 day ago
@grantmethestrength MCS requirements for DHW capacity h...
