Came across two small turbines. Will contact the respective manufacturers for more details and what additional kit is required. Not cheap though:
https://www.truenorthsailing.co.uk/wind/1710-6475-silent-wind-400-pro-wind-generator.html#
https://futurenergy.co.uk/feshop/airforce-1-wind-turbines/
Found out CAT in Wales does a domestic wind turbine day training. I'll let you know if it's interesting in a couple of weeks.
https://cat.org.uk/events/build-a-small-wind-turbine/
https://cat.org.uk/events/renewables-for-households-wind-turbines/
They do a variety of courses on different subjects.
Interesting place to visit and chat to people generally
@jeff, sounds amazing. It says all materials provided. Does that mean you’ll walk out of there with a turbine? That would be tremendous value. 😀
Posted by: @editor@jeff, sounds amazing. It says all materials provided. Does that mean you’ll walk out of there with a turbine? That would be tremendous value. 😀
It is a two day residential group course where you get to make and build a turbine on site as a group including food and accommodation.
Everyone on the course doesn't walk out with a turbine unless i missed something.
Still good value to learn about these things.
Am sure you would pickup really practical real world info on domestic solutions in general.
@jeff, I was joking about walking out with a turbine. 😀
It does genuinely sound like a very interesting course. Hands on training like that is amazing.
Hadn't even seen that one! I found the one day course:-
Figured it'll be a good start to see what the training is like there.
Just seen a group in Bristol has privately financed a £4m turbine.
I wanted to kick-start this topic again.
A quick sweep online (somewhat remarkably) suggests there are still virtually no credible small-scale domestic wind turbines on the market beyond Tesup.
Has anyone come across anything genuinely interesting or technically robust in the sub-5 kW domestic space?
@transparent, this is firmly your territory and you’re undoubtedly the genius in this domain. If ever there was a gap in the market for a properly engineered product, this feels like it. Perhaps we should be raising capital and making one!
Posted by: @editorI wanted to kick-start this topic again.
For a couple of years b&q sold one, but then stopped I presume because no demand. They are quite popular for narrowboats see eg https://www.ecopowershop.com/collections/marine-boat-wind-turbines
My limited understanding is that small scale domestic wind is simply not practical. The size of the turbine (blades) and mounting height above roof/tree lines required to make it viable means that unless you have a farm or small field, wind is probably not the answer.
For example, take a look at SD Wind's 3kW and 6kW turbines:
https://www.windandsun.co.uk/pages/sd-wind-energy-turbines
The 3kW unit has a 3.9m diameter, and at a wind speed of 12m/s (25mph) it is rated to generate 2.5kW. Google AI tells me I'd need to mount it at 30m or higher (I had initially estimated 10m above roof/treelines), particularly in areas with buildings or trees, to achieve wind speeds of 12m/s. Simply not practical for most domestic properties?
- 474 Online
By Renewables345 , 23 minutes ago
By MartinHook_UK , 34 minutes ago
By benson , 43 minutes ago
By cathodeRay , 2 hours ago
By bobflux , 2 hours ago
By bobflux , 3 hours ago
By Jonatan , 7 hours ago
By bobflux , 14 hours ago
By Batpred , 14 hours ago
By Transparent , 18 hours ago
By bobflux , 18 hours ago
By Toodles , 21 hours ago
