Mitsibushi Ecodan U...
Mitsibushi Ecodan U4 error code: thermistor values
2 Users
3 Reactions
(@hughes674)
New Member Member
Hi All
Have had the pleasure of a trouble free air source heat pump for 8 years.
Came on today with a U4 error code and tripped the RCCB. The manual states that the error refers to one of the thermistors in the outdoor unit (TH32,TH33,TH6,TH7 or TH8).
The Heat pump is a Mitsibushi Ecodan PUHZ-W85VHA2R1-BS UK
Would anyone know where I can get the resistance values for the thermistors to check which one is faulty?
Thanks in advance.
This topic was modified 2 years ago by Mars
Welcome to the forums @hughes674the resistance values you're looking for are available in the ME Engineer app.
ME Engineer App
(@hughes674)
New Member Member
@editor Hi
Thank you. Appreciated.
Bad news checked all the thermistors apart from TH8 as cant get to it and they all are within range.
Got a feeling its gonna be expensive.
And here's a suggestion from Mitsubishi's Technical Trainer. This video shows how to use the Main Remote Controller to look at thermistor readings, which can help narrow down which thermistor needs testing.
(@hughes674)
New Member Member
@editor Thank you.
All the thermistor temperature readings look right but not displaying anything for TH8.
Is there a way of the controller telling me which thermistor is faulty?
@hughes674 so the technical trainer has informed me that if have melcloud installed you can call the technical help desk and they will be able to access the system remotely and provide further guidance. If not, it’s a case of getting an engineer out unfortunately.
(@hughes674)
New Member Member
Hi All
Mitsubishi Ecodan PUHZ-W85VHA2R1-BS UK
Following on from a U4 fault on my heat pump I have now finally received the TH8 thermistor from Mitsubishi.
Issue I have is the power board needs removing to replace it but cannot get the power board off. released the rubber clips but the board is still firmly attached somehow.
Has anyone had any experience removing these?
