[Sticky] Struggling to Find a Top Heat Pump Installer? We Can Connect You With the Best Installers in the UK
Posted by: @editorPosted by: @jamespaI had exactly the same experience, 2x+ oversizing (16kW 'surveyed' vs 7kW measured).
I just don’t understand how this is still happening and this problem is not going away. Our local heating engineer (who will be working on our system soon) stopped by for a quick chat and coffee yesterday.
He’s just won a new ground source heat pump project on a large new build nearing completion, 450sqm with a heat loss around 13. The homeowner, he says, is disengaged and not asking any questions, and the proposal they nearly accepted was for a cascade system with 2 x 12kW units.
In fairness my experience was 2 years ago. However the example you quote and that of @simonb seems to confirm it is still happening.
The change to the calculation methodology which was mandatory from mid last year should have dealt with the ACH problem at least to an extent, assuming of course that installers have updated their methodologies. However it wouldn't do anything for the problem of ignoring fabric upgrades (GIGO!) and possibly not for double counting. As you say there still appear to be some ludicrous numbers out there, so ludicrous that a bit of elementary sense checking would easily spot them.
- 313 Online
@travellingwave, thanks for the post and kind words abo...
By Mars , 56 seconds ago
RE: Knock on effective of balancing radiators
@jamespa Thankfully we'd already experienced chrome ...
By Bash , 2 minutes ago
@editor I'd missed that, and it's a very good response ...
By Sheriff Fatman , 3 minutes ago
Absolutely, this is typical usage for Octopus Cosy user...
By Old_Scientist , 55 minutes ago
RE: New Solar, Batteries, Air Source and Under Floor Heating advice please
In a word don't, or at least think VERY hard before doi...
By JamesPa , 56 minutes ago
There has been quite a bit of discussion (mostly on OEM...
By MartinRobinson , 1 hour ago
@kev1964-irl At the outset just to say I am not a plumb...
By GC61 , 2 hours ago
@benson My system is a "simple" one: no DHW, no defrost...
By Tasos , 2 hours ago
When I saw the world flawless that immediately to me me...
By Bash , 3 hours ago
Thanks for confirming. I should have suspected "C16" (i...
By Batpred , 4 hours ago
RE: Our Experience installing a heat pump into a Grade 2 Listed stone house
The years between oil use and the heat pump (roughly 20...
By cathodeRay , 4 hours ago
@af1 My EPC rating jumped from E to C after installatio...
By dr_dongle , 4 hours ago
Hello fellow Daikin owner, my installer retro-fitted my...
By Toodles , 5 hours ago
@odd_lion the minimum MCS requirement is 2.8. I don't...
By benson , 5 hours ago
RE: Advice on potential HW Cylinder size
I think the comment about heating from cold is quicker ...
By sjcsystems , 15 hours ago
RE: Ideal HP290 14kW ASHP - how to optimise
Hi You can get a stethoscope for less than 10€ on Ama...
By bobflux , 15 hours ago
Your DT is to low, you do not have enough heat exchange...
By ASHP-BOBBA , 18 hours ago
I am aware. But is your chart direct from a Pace BMS ap...
By Batpred , 18 hours ago
RE: Call for heat on open loop weather comp system
I don't know Grant system but most ASHP are very simila...
@painter26 — good idea. Please do let us know what he s...
By cathodeRay , 19 hours ago
@robs — thank you for your as ever valuable comments. T...
By cathodeRay , 21 hours ago
Yes, but I need to reopen the battery box.. I just noti...
RE: The Hidden Secret to a Successful Heat Pump: Pipe Size Matters
If your heat loss is only 4kW and the pipes leaving the...
