[Sticky] Rate the quality of your heat pump design and installation
@cathoderay in that case the second category needs to be removed as how do you fix a snag without a return visit?
Im glad you feel flawless is a clear definition but those of us who clearly aren't as all knowing as you perhaps need it clarified in the description!
That all looks very neat and professional and thank you for posting. Its good to hear from householders with successful installs to remind us that these are very probably the vast majority, but of course also the people who have relatively little reason to post here!
The only comment I would make is that the hot water pipework should normally be insulated for (at least) the first 1m from the tank.
@gmuzz I completely agree. Given the ‘clarification’ that flawless obviously means including small snags, I fail to understand what the difference between the top two poll responses is? It’s not a big deal until the data is used to make claims like ‘only 10% of installations are to the required standards’. I would suggest 5 categories are enough and 1 & 2 should be combined.
Posted by: @gmuzzIm glad you feel flawless is a clear definition but those of us who clearly aren't as all knowing as you perhaps need it clarified in the description!
I think that is an excellent suggestion, I am sure @editor will attend to it.
To be clear. I see flaw-less as fault-less, and a fault or defect is something that compromises operation in some non-trivial way or other, if such a flaw isn't present, then the installation is in my view flaw-less.
I suggest there may be another category above flawless, one in which the installer has gone above and beyond the call of duty. I have no doubt such installers and installations exist, indeed on one level (but not perhaps on some other minor points) my own installer achieved just that. Four years on and I am still grateful to him.
@cathoderay did you re read your first paragraph? To be fair it does a very good job of illustrating my point. Do you really think the rest of the population has your interpretation of what flawless means, I don’t.
You said “Flawless as the top category is fine. It does not mean perfect, it means flaw-less, no flaws.” Really?
The Poll wording is actually “Flawless – perfect in every sense”, seems a bit contradictory based on your definition.
You suggested “But on this we can agree, flawless can include snags (which haven't reached the defect/fault threshold, hiccups if you like), and a large part of how an installation remains flawless is how any snags/hiccups get dealt with.”
I don’t agree, but if you’re correct, how does poll option one differ from option two?
@woofers64 — I do agree the top two definitions and their distinction could be clarified and that is why I said I am sure @editor will attend to it.
When I saw the world flawless that immediately to me meant perfect.
I was once told aiming for perfection is pretty much impossible, unachievable and comes with an unnecessary level of stress and anxiety for all involved and best off avoided.
If it was me I'd still leave the flawless category in as someone may actually have achieved this (which would be a very small number), but add in another category "excellent", which would cover the best installations.
Is this ASHP install OK?
7 months ago
My Journey to Finding the Best Heat Pump for My Home in France
12 months ago
What is the most important factor for you when choosing a heat pump brand?
2 years ago
Mid terrace - ASHP Install location
2 years ago
Any installer recommendations for Samsung ASHP?
2 years ago
Currently viewing this topic 2 users ( Bash, cathodeRay ) and 10 guests.
Recently viewed by users: Majordennisbloodnok 35 minutes ago, Woofers64 53 minutes ago.
- 295 Online
Government strategy is for heat networks to provide 20%...
By Transparent , 38 minutes ago
When I saw the world flawless that immediately to me me...
By Bash , 43 minutes ago
RE: Knock on effective of balancing radiators
Thanks @jamespa Yes, I'd be leaving several radiator...
By Bash , 1 hour ago
Thanks for confirming. I should have suspected "C16" (i...
By Batpred , 1 hour ago
RE: Our Experience installing a heat pump into a Grade 2 Listed stone house
The years between oil use and the heat pump (roughly 20...
By cathodeRay , 1 hour ago
@af1 My EPC rating jumped from E to C after installatio...
By dr_dongle , 2 hours ago
Hello fellow Daikin owner, my installer retro-fitted my...
By Toodles , 2 hours ago
@odd_lion the minimum MCS requirement is 2.8. I don't...
By benson , 3 hours ago
RE: Advice on potential HW Cylinder size
I think the comment about heating from cold is quicker ...
By sjcsystems , 12 hours ago
RE: Ideal HP290 14kW ASHP - how to optimise
Hi You can get a stethoscope for less than 10€ on Ama...
By bobflux , 12 hours ago
@editor Hi Mars Just reading the ultimate heatpump...
By Travellingwave , 15 hours ago
@tasos as above the pump is always running... Thanks ...
By benson , 15 hours ago
Your DT is to low, you do not have enough heat exchange...
By ASHP-BOBBA , 16 hours ago
I am aware. But is your chart direct from a Pace BMS ap...
By Batpred , 16 hours ago
RE: Call for heat on open loop weather comp system
I don't know Grant system but most ASHP are very simila...
@painter26 — good idea. Please do let us know what he s...
By cathodeRay , 17 hours ago
@robs — thank you for your as ever valuable comments. T...
By cathodeRay , 18 hours ago
Yes, but I need to reopen the battery box.. I just noti...
By Batpred , 22 hours ago
RE: The Hidden Secret to a Successful Heat Pump: Pipe Size Matters
If your heat loss is only 4kW and the pipes leaving the...
My 2 bed mid-terrace definitely dropped consistently af...
By RadWhisperer , 1 day ago
With complete radio silence from Peak and no sign of th...
By DaveC , 2 days ago
No you arent, because you dont need any, and furthermor...
