@dansus, I’ll have a proper look through the app tomorrow. We don’t have smart tariffs at home, so I’ve never really played around with those settings. My understanding, though, is that you manually set the charging times and electricity rates in the app, rather than the tariff provider dynamically pushing its rates and timings directly to the battery.
Agile et al, are linked to dynamic wholesale prices, so the system has to adapt to ever changing prices and charging times. Hence the need to make use of the providers API.
Most systems work with Agile and FreePhase now, so i would expect Indevolt to offer the same service.
Posted by: @dansusAgile et al, are linked to dynamic wholesale prices, so the system has to adapt to ever changing prices and charging times. Hence the need to make use of the providers API.
The SMETS2 spec, approved by Parliament in Nov'14, stipulates the Smart Meter mechanism to hold the tariff data.
That was defined and approved by MPs in order for the bill-payer to be certain of the price they were paying. It could be displayed on the IHD and read manually, and also picked up by household appliances (directly or via a decoder) for use in automated control. Putting the tariff data in the meter on a rolling basis means that it is also correctly applied when your tariff is using the Randomised Offset to the tariff-table. Not all tariffs do so, which causes surges on the grid.
It is a lapse by Ofgem which means that this SMETS2 mechanism isn't enforced. Energy Suppliers often don't download the current tariff data into the Smart Meter.
Parliament foresaw obvious problems with using the internet for each Supplier to allow devices to pick up tariff data via an API.
Unfortunately, that's the situation we're ending up with.
The outage of Google Cloud data in Europe yesterday (20oct26) should serve as a wake-up call, alerting us of the lack of resilience of an internet-based approach.
Posted by: @editor[...] rather than the tariff provider dynamically pushing its rates and timings directly to the battery.
Allowing a 3rd party to directly apply data to an energy device in my home raises all sorts of alarms in my head!
Even having a 3rd party reading data from a domestic energy device is seriously problematic.
We found that out when GivEnergy collapsed earlier this year!
@dansus, yeah, that's exactly what I wanted to check whether there's a dynamic option, and there is, but it appears to be blanked out. So you can select Octopus under dynamic tariff (not ToU), but solution is blanked out. @indevolt-tech @indevolt-uk can you please advise.
It was a power outage. If the magic pile of tricks feeding data out has a power cut then how the data is provided seems a bit irrelevant.
Anyway the real risk is mostly quite different - it's someone hacks the provider of the data, pushes out negative prices when it's actually 50p/kWh and watches from the side (or a system failure does similar).
Google Cloud outage:
Posted by: @etchedpixelsIt was a power outage. If the magic pile of tricks feeding data out has a power cut then how the data is provided seems a bit irrelevant.
Let's not jump to the conclusion that this was a power outage on the 43MVA Transmission Grid feed from Waltham Cross GSP (Grid Supply Point) to Google's European data centre at Platinum Way EN8 8YD
Those servers have UPS supplies and triple power cabling to provide system resilience.
Then there's that orderly row of 23 massive diesel generators which are very visible in Google's own publicity materials:
There are other major infrastructure centres nearby, including Vodaphone. Yet none of them suffered a power outage yesterday.
yes, the irrelevance is also that nobody would run anything critical on a single datacentre in a public cloud since as long as I remember
Posted by: @transparentThe outage of Google Cloud data in Europe yesterday (20oct26) should serve as a wake-up call, alerting us of the lack of resilience of an internet-based approach.
Also..
It saw cascading effects worldwide: taking out the Roblox game and Signal messaging app and causing smart mattresses worldwide to suddenly heat overnight and toast their occupants. 🤭
@editor We will check and get back to you soon.
⚡ Indevolt UK Technical Team
Official Support | Smart Energy Storage & Home Automation Solutions
🛠️ Discord: https://discord.gg/aZTvvTK9pt
📧 Support: support.uk@indevolt.com
@dansus yeah, that definitely needs fixing. Good spot. Well done.
Currently viewing this topic 5 guests.
- 2,817 Topics
- 3,162 Online
- 7,230 Members
By David , 2 hours ago
By EtchedPixels , 4 hours ago
By Toodles , 7 hours ago
By Toodles , 9 hours ago
By EtchedPixels , 10 hours ago
By JamesPa , 10 hours ago
By Chilli304 , 14 hours ago
By JanHarley , 15 hours ago
By JamesPa , 18 hours ago
By bobflux , 1 day ago
