Reliable, easy to use home battery options
Hi everyone,
I wondered if I could ask for your thoughts on a reliable, easy to use home battery solution that will provide backup power in the event of grid failure and lower energy costs?
We have a Vaillant Aerotherm Plus 7kw ASHP and a 2.9kW solar array. In December the ASHP consumed 512kWh of electricity, although obviously that varies hugely and ranges up to 50kWh on really cold days. Last year we imported 4967 kWh of energy from the grid and generated just over 3000kWh, exporting about half of that.
We are currently on Ovo’s Heat Pump Plus tariff which sadly ends this month. This has prompted me to look at battery storage, along with concerns about future grid reliability. I recognise that I won’t achieve payback on the cost of battery storage.
The system needs to be as idiot proof and simple to operate as possible. Neither my partner nor I have the technical skills to be tweaking settings! I’d also like it to play nicely with smart tariffs like Ocotpus Agile to maximise potential savings and lower our carbon footprint.
I’ve had quote of £7124 from Octopus for a Powerwall 3, retaining my existing PV inverter. They have said that this is the only system they offer that can provide a true UPS. I don’t like Tesla as a brand and wondered if there are any other options that folks on here would suggest that would meet my criteria?
I also wondered if 13.5kWh is sufficient given our consumption or if I should be looking for a larger system?
Thanks very much for your thoughts.
Great topic… I was actually going to ask something similar myself. The Powerwall (our neighbour has one) is fairly idiot-proof, which definitely has its appeal (despite its cost), but I’m really interested to hear what other options people are running and how they’re getting on with them. I known there’s a lot of threads on the go along similar lines, but it’d be good to discuss pure ease of use, installation and costs here.
Beyond simple ROI, which is obviously easier to achieve with cheaper, semi- or unbranded kit that isn’t always the most user-friendly, two things really stand out for me: how much storage you actually need and whether the system can properly “island” during an outage.
Taking heating and the heat pump out of the equation entirely, our base load sits just under 1 kWh. To keep the maths simple, call it 1 kWh an hour to run fridges, electronics, lighting, our home sewage treatment plant, etc. We both work from home, so that load is fairly constant.
In a prolonged power cut like the one we’ve just had, that means we’re looking at around 24 kWh of usable storage just to get through a day. PV might top that up a little, and yes, you could conserve by cutting lighting and non-essentials, but it’s still a lot of battery capacity, which means space, complexity and cost.
That’s why I’m really keen to hear what others are doing, especially around resilience rather than just payback. Grid reliance, outages and energy security feel like they’re going to become much bigger conversations in the months and years ahead.
FWIW I started a thread here just a few days ago trying to understand the options for islanded (ie able to operate when grid disconnected) and non islanded systems. This was quite technical and currently totals 11 pages. It turned into a deep discussion of earthing arrangements (which are rather important). Suffice it to say its not trivial particularly if, like me, you also have solar with a FIT tariff which thus needs a separate generation meter.
I haven't yet reached a conclusion but the viability (for me) rests on combining the work to install the battery with a CU upgrade that is anyway well overdue and doing the whole thing as one job. This runs into the problem that the battery inverter people tend to be specialists and its as yet unclear to me where I can draw the line between a general electrician to do the bulk of the work, and a battery inverter specialist (or me) to do the remaining work.
The UK average house consumption (excluding EV and Heat pump) is less than 0.5kW (so 12kWh in 24 hrs) implying @editor, you must be running something high current for quite a long time!
Posted by: @jamespaThe UK average house consumption (excluding EV and Heat pump) is less than 0.5kW (so 12kWh in 24 hrs) implying @editor, you must be running something high current for quite a long time!
We are, quite literally, power users!
The other question I have is around safety. Are the cheaper, no-name or white-label systems genuinely safe and stable over the long term when it comes to cell chemistry, battery management systems and the risk of thermal runaway?
I’m especially curious about how well these systems handle fault conditions (over-charging, deep discharge, cell imbalance, inverter failure or high/low ambient temperatures) and whether their protection mechanisms and certification regimes are truly comparable to the bigger, more established brands.
Cost and capacity are one thing, but when you’re putting a large amount of stored energy inside or attached to your home, I’m keen to understand where the real risks sit, what standards actually matter and whether paying more is buying genuine safety and robustness or just a logo.
Posted by: @editorThe other question I have is around safety. Are the cheaper, no-name or white-label systems genuinely safe and stable over the long term when it comes to cell chemistry, battery management systems and the risk of thermal runaway?
There is, of course, the question of whether the more expensive branded systems are indeed all those things too.
All, of course, within the context of kit - cheap or expensive - that passes the necessary certifications for domestic installation in the UK.
Currently viewing this topic 1 user ( Broadsman ) and 7 guests.
Recently viewed by users: Majordennisbloodnok 45 minutes ago, downfield 58 minutes ago, trebor12345 16 minutes ago, JamesPa 51 minutes ago, Mars 41 minutes ago.
- 2,418 Topics
- 54.8 K Posts
- 381 Online
- 6,098 Members
RE: How to use my Hanchu battery storage for home without it feeding back into the grid?
Hi. My Hanchu battery system is controlled by the (Lux...
By SKD , 3 minutes ago
RE: Ecodan Pump Issues… Circulation pump turns off when heat pump compressor turns off
Unfortunately it seems to be oversized. I can answer to...
By ASHP-BOBBA , 8 minutes ago
RE: Installer Fitted 9kW Instead of 11kW Heat Pump and Changed MCS Paperwork - What do I do?
@jamespa thank you again. Apologies I missed you pointi...
By MairiA , 23 minutes ago
RE: Reliable, easy to use home battery options
There is, of course, the question of whether the more e...
By Majordennisbloodnok , 46 minutes ago
In the Home Assistant firmware the data points...
By F1p , 12 hours ago
RE: GSHP WOES! Midland based engineer recommendations?
@johnbroome if it is not the pressure in the expansion ...
By ASHP-BOBBA , 12 hours ago
So I hear the export MPAN that UKPN assigned should be ...
By Batpred , 15 hours ago
From what I read, the Solis has a very long list of err...
RE: Ideal HP290 14kW ASHP - how to optimise
Roughly this should cost you £250-£300 per peak month a...
By ASHP-BOBBA , 16 hours ago
RE: New Daikin 11kW Altherma 3M install - is it working as it should?
@toodles Thank you for your input. As the days have got...
By Synthbuilder , 19 hours ago
RE: Fan unit Making terrible noise HELP!!
@gutoffowc Oh no, sorry to hear that, are you in the Ke...
By ASHP-BOBBA , 21 hours ago
RE: Sunsynk Whole House Backup Issue
@sheriff-fatman - could you please re-post that in the ...
By Transparent , 22 hours ago
RE: Running my new Nibe ASHP efficiently
I didn't. I spent a while manually messing around with ...
By jamieheatpumpnew , 24 hours ago
RE: I’m glad the cold spell is over!
I comparison with the 65kWh used above yesterday was on...
By Judith , 24 hours ago
I should think so, I thought that pretty much universal...
I'm also inclined to look into how a defrost is actuall...
By cathodeRay , 1 day ago
MLCP (Multi-Layer Composite Pipe) for ASHP
@editor nope. The info you reported was sufficient for ...
By iotum , 1 day ago
RE: Experience - New Build / Complete New Heating System
@vincro I would be surprised if it is much above 5 to 6...
By ASHP-BOBBA , 2 days ago
