Pump and Esbe mixin...
Pump and Esbe mixing valve for UFH
2 Users
2 Reactions
(@andycoo)
Hi everyone
Looking for some help with pump and esbe mixing valve selection for our UfH. We installed the loops and manifold in the Summer along with our geocell and limecrete floor.
Now we are the stage of selecting and installing pump and mixing valve.
This is DIY as we were unable to find anyone in Cumbria who was prepared or able to do this for us. So I’d really appreciate the group’s help to get this right.
I can share my calcs but I’m planning to get VRG133 (compression fitting) with Kvs 2.5. My question for now is this: Why do the pros use the VRG131 with internal thread and then require a separate threaded to 22mm compression adaptor?
It seems to be the norm in most information I’ve seen so I’d like to understand why this is the case.
thanks in advance for any help and advice you can give.
Andy
This topic was modified 5 months ago by Mars
Pirate Rich
(@pirate-rich)
Trusted Member Member Professional Installer
VRG131 is just a popular valve and can be adapted to any size using fittings. The pump can be chosen based on the pressure loss.
What will be in control the ESBE valve actuator?
We are an ESBE specialist supplier, so I can help with sizing, but I need to know max flow temp, kW input and design DT.
Richard, Rich, Dick, Captain or Pirate... I answer to them all in any sequence! 🏴‍☠️☠️👍
See my heat pump running live here... 👉 HeatPumpMonitor.org 👈
Buying from 🏴‍☠️ PirateHeatingSupplies.com 🏴‍☠️ means you support my family owned, independant business! 🙏❤️👍
(@andycoo)
@pirate-rich Thanks for the quick reply! That makes sense, it’s an easier option for wholesalers and plumbers using a lot of valves that they just need one type to cover multiple scenarios.
But for little old me, using a compression model is no issue except the short wait to get one from Esbe? I think you already mentioned this lead time in your email reply to me a couple of weeks ago.
I’m going to use this for the valve control (I’m on biomass) Clima600
(@andycoo)
So my next question is about calculating pressure loss for pump selection.
For the UFH loops it’s ok as there’s a table in the Design Guide, and the Esbe app gives me a loss number for the mixing valve, but I haven’t been able to get any info about my 7port manifold despite asking the supplier.
Is there a good enough rule of thumb I can use for this?
