Posted by: @cathoderay. What we see here is you demonstrating the very considerable gains (comfort and others) set against modest pains (costs), thus achieving the magic double the gain vs the pain approach that neutralises the inhibitory effect of loss aversion.
That's the key in my view. To change behaviour requires both a positive reason and that the positive significantly outweighs the negatives. In addition the negatives must be manageable.
Currently neither of the first two conditions are met for most people in most circumstances, and there are many circumstances (eg leasehold flats) in which even the third is not met.
Fixing one thing alone (eg the spark gap) will help but is not on its own sufficient. The system as a whole needs to be redesigned.
The government and industry have a lot of work to do.
Posted by: @hml1827We also own a small flat on the south coast. That has a gas combi boiler which is nearing the end of life, but there is no rational path for replacing the boiler with a heat pump. No location for the outdoor unit, difficult to get permission from the freeholder, no running cost saving. When it needs replacing it will be with another combi boiler
i hear there are heatpumps that can be installed indoors exactly for flats and just expel the cold air
Posted by: @batpredPosted by: @hml1827We also own a small flat on the south coast. That has a gas combi boiler which is nearing the end of life, but there is no rational path for replacing the boiler with a heat pump. No location for the outdoor unit, difficult to get permission from the freeholder, no running cost saving. When it needs replacing it will be with another combi boiler
Trianco activair 3kW.
Also several A2A models most notably by Panasonic
There are a bunch of systems that internally install and are used for flats and Nimbyzones but the better ones are generally proper systems that involve drilling two large holes through the wall, fitting a liner and cover (all done from inside) and then mounting the heatpump onto it.
The problems with approach are
- getting the feeholder to agree to drilling a hole in the wall
- the COP is generally lower (3.5 or so not the easy 4 you get on a proper install)
The other option is to simply use a "portable" unit thereby ensuring you can tell the feeholders where to go stick their noses, and it's one of the cases where things like the self install Midea Portasplit can shine, and indeed it's the mainland EU equivalent of that market it was really designed for.
The through the wall type units btw are brilliant for garden offices and the like because sticking a 15cm hole through a sheet of glorified insulation panel is really easy to DIY, where as sticking a 15cm hole through a cavity wall is not.
Flats are a real problem because the correct answer is almost always communal heating/cooling and the UK simply doesn't have the right legal and financial frameworks to make it behave sanely, although it's very slowly getting better. This is going to become a real problem with the 2030 EPC and rental rules, especially as some feeholders see this as a golden opportunity to get rid of all the "undesirables" from their blocks.
Posted by: @etchedpixelsThere are a bunch of systems that internally install and are used for flats and Nimbyzones but the better ones are generally proper systems that involve drilling two large holes through the wall, fitting a liner and cover (all done from inside) and then mounting the heatpump onto it.
Which one if several places we need legislation.
Freeholders should be obliged to permit it at no cost and with no requirement for survey and a ban or requiring any other costly paperwork as a way, in practice, to stop it happening. How different is it really to a flue for a boiler. Bigger yes, two of them yes, but really not existential for the building.
Posted by: @etchedpixelsFlats are a real problem because the correct answer is almost always communal heating/cooling and the UK simply doesn't have the right legal and financial frameworks to make it behave sanely,
Agree technically, but in reality it becomes another lucrative opportunity for the freeholder which will be minimally maintained but where prices will be steadily hiked up.
If people (and corporations controlled by private equity funds) were honest and decent it makes sense, they aren't so many will, rightly, see such a system as a trap for the resident. As you say we simply don't have the legal framework for such a system.
@batpred Yes. AIUI they are not very efficient, are pretty noisy and only heat/cool one room. (And demand the drilling of 2 big holes in the wall.)
A small multi split system is probably the best answer for small flats, but you still have the issues of external unit siting and hot water provision.
Posted by: @jamespaIf people (and corporations controlled by private equity funds) were honest and decent it makes sense, they aren't so many will, rightly, see such a system as a trap for the resident. As you say we simply don't have the legal framework for such a system.
We sort of do - co-operatives this works, but making it work in most typical fleecehold setups does not, and apart from a co-operative you've then also got all sorts of fascinating unnecessary regulatory hurdles too.
To go back to the psychology, I think a good comparison is EV take up.
When the first practical mass market EVs (Nissan Leaf, Renault Zoe) were introduced they were appealing to people like me but were excessively expensive and only really suitable for use as a local runabout, so only the very committed would buy them. There were no used ones, so no secondhand market which is where most private cars are bought.
Gradually they've improved and today we have a situation where they are competitive in price with ICE vehicles, have usable range together with an adequate public charging infrastructure, and a substantial used market, so they have reached a tipping point. They will soon have over half the new car market.
However, one of the most important factors is that as they became more common normal people could see and experience them and discover that all the FUD from the fossil fuel pushers was just that. Once they experience an EV either personally or through an acquaintance and find how much better than ICE cars they are, the reluctance breaks down.
The same thing needs to happen with heat pumps. A large installed base so that people get a degree of familiarity with them and see that they work reasonably well is a necessary pre-requisite.
But that's not enough. The spark gap needs to get to less than 2.5 to 1 so that even a minimal installation a la Graham Hendra (just replace a boiler) system is cost effective and in that case the system cost shouldn't be much more than a straight boiler swap. Dodgy grants not needed.
Posted by: @hml1827A small multi split system is probably the best answer for small flats, but you still have the issues of external unit siting and hot water provision
The trianco product is a2w with no external unit. You still have to solve dhw of course but I can certainly think of flats that it could work well for, combined with a modest dhw tank, if the freeholder didn't block the two holes through the wall. The flats I have in mind have exposed noisy combis so I doubt it will be any more disruptive. I have no idea at all if it's any good of course
One question for your friends, are they using the system to heat as well as cool, or just to cool for a few days in the summer?
Put another way, can A2A serve as a 'Trojan horse' (to convert heating to heat pumps) for those who can afford the luxury, or will it turn out to be just another way to increase our energy consumption?
All three had a strong desire to have A2A for cooling. In two cases, this was due to negative effects on their self-employed businesses due to sleep deprivation caused by multiple consecutive nights with little sleep during the heat waves. In this sense, air-conditioning became an essential.
#1 was concerned about affordability, and went from can I afford this, to this is a "no brainer" once the potential savings on heating costs were explained. In this case, there is an expectation of around 4000kWh reduction in gas demand, replaced by about 700kWh of electricity demand (A2A SCOP 5.2, boiler 0.9). Assuming 9.76p per unit for gas, and a half price time of use tariff for electricity (full cost 30.28p per unit), this amounts to a £285 saving per year. Assuming £85 for A2A maintenance and 400kWh at a SEER of 9.3 for cooling, i.e. 43kWh or £13 for the full price electricity to do that, leaves £187 saving per year in today's prices. Assuming a 15 year life and a £2200 cost, the A2A pays for itself in just under 12 years. In other words the air-conditioning comes for free, with a nice reduction in CO2 emissions thrown in. (Of course electricity and gas prices could easily change, but the point is there is a significant reduction in energy bills to be had).
#2 had realised that air-conditioning was going to be a necessity for a home office loft conversion. The fact that A2A could do the heating as well meant that the existing wet system did not need extending into the loft saving substantial amounts of plumbing and two new radiators. Further a multi-split A2A system might be able to heat and cool the two existing floors. They are currently looking at whether trying to get a BUS grant for A2A and do away with the wet system altogether is viable.
#3 were also fed up with being too hot, and looking to fit air conditioning in the two main bedrooms. To me this one is the best example of A2A as a potential Trojan Horse. Using the A2A for heating will prove it works and greatly increase familiarity with heat pumps. This house which has underfloor heating throughout would be just about the ideal candidate for an A2W heat pump.
I think A2A can work as a sort of Trojan Horse, increasing familiarity with heat pumps and shifting physiological barriers against getting an A2W system. The potential downside is that the savings that can be made by simply dumping some heat into the house overnight with the A2A mean that the economic argument for immediate replacement of agas boiler with an A2W heat pump becomes much weaker. That's the somewhat unusual situation that I find myself in. I could replace the gas boiler with an A2W heat pump, however, unless the gas price goes substantially over 12p per unit and stays there, I would be losing money by doing so, and that's with Solar PV and a reasonable amount of battery capacity.
In a way, A2A could be a partial solution that can easily be adopted by the majority of homes. It can be installed relatively cheaply alongside an existing gas boiler that has a lot of life left in it, giving useful savings in CO2 emissions and cooling functionality at no net cost. Then in 12-20 years time revisit the system as a whole and consider whether both can be replaced by a system that does both A2W and A2A in a single unit.
Over the next couple of years, unless there are drastic changes, there is a possibility that the market for A2W falls apart. The early adopters will have taken advantage of the BUS grant to get an A2W system installed, accepting the risks and the capital costs to reduce their carbon footprint. However, next up, the early majority are pragmatists and if the price is too high with no BUS grant and the perceived risk is too great, then they simply will not buy.
Posted by: @rob-of-yorkOver the next couple of years, unless there are drastic changes, there is a possibility that the market for A2W falls apart. The early adopters will have taken advantage of the BUS grant to get an A2W system installed, accepting the risks and the capital costs to reduce their carbon footprint. However, next up, the early majority are pragmatists and if the price is too high with no BUS grant and the perceived risk is too great, then they simply will not buy.
Agree. Government and industry have to work out how to attract the majority or face policy failure.
Posted by: @cathoderayMy suggestion (it is no more than that at this stage) is that the primary decision to avoid a heat pump is psychological (emotional) and then the logical decisions (too expensive, too disruptive, too little available space etc) follow. Countering those logical arguments with logical counter-arguments fails because the mind has already emotionally decided.
I totally concur... People are little more than 'justification machines'. We decide a position and then find points and/or 'facts' to back that position up. Even after a lifetime of working as a Pharma research scientist, I firmly believe this is true and I'm always suspicious of my own decisions because of this bias.
If you are 'good' at critical thinking, you might set out a list of sensible and justifiable points backed by scientific verification... But mostly, those points don't survive contact with hard reality... For the general public, I suspect few base their decisions on hard, cold facts but rather 'gut feelings'.
Installed solar [7.44 kWp] and batteries [Sigenstor 3 x 8kWh] and 12 kW inverter in July 2025.
- 2,828 Topics
- 67.3 K Posts
- 2,319 Online
- 7,249 Members
