What is the Heat Ge...
What is the Heat Geek Guarantee?
6 Users
7 Reactions
Your energy: 74 kWh
@jamespa great question as we’ve not seen a single mention of the mini store on the forums.
(@michael-w)
New Member Contributor Professional+
@editor We've only installed one so far, a 60XS model, but it's performing well from a functionality point of view.
That said, I'd always choose a standard unvented cylinder where possible. They're generally more efficient and offer greater hot water storage capacity. The Mini Store isn't a direct replacement and needs to be designed carefully around the property's hot water demand and the overall heating system.
Our installation is in a small property with one shower, one basin and a kitchen sink. We also fitted 5 lpm flow restrictors to all outlets as part of the design. In that application, it's working well.
The Mini Store does have some advantages beyond being compact. There's no requirement for a D2 discharge pipe, which can make installation easier in certain properties, and it can be a useful option where space constraints make a conventional cylinder difficult or impossible.
For the right property and when designed correctly, I think it's a good solution. But if space allows, I'd still lean towards a standard unvented cylinder.
Your energy: 79 kWh
Posted by: @michael-w
Thanks.  That's exactly what I was expecting/hoping for if it does in fact fill a niche.  I think it's been clear all along that where a standard cylinder fits that is a better choice, but as you say some properties won't fit that profile.
This post was modified 6 months ago by JamesPa
(@batpred)
Your energy: 20 kWh
Thanks, we also heard about the thermal store, to be used in combination with a cylinder I believe.
It was described as similar to a combi, but to be honest, I could not see how, as our combi is 28kw and the HeatPump being considered is 7kw (even if it can deliver slightly more in some cases). It would have been nice to see a diagram of how the thermal store would work.
That also came up in the initial proposals that the system gave and it was obviously adding to the cost. We were not interested, as it could be avoided by using a smaller cylinder. We ran out of time when going through all the options. Given hot water will be 10-15% of the cost,  investing more in it will most likely have lower return, compared to upgrading rads..
Page 2 / 2
