Problems with sizin...
Problems with sizing a replacement for a Viessmann Vitocal 200-S
6 Users
14 Reactions
 jon
(@jon)
@judith Thanks very much for this! My room by room calculation, done on my own spreadsheet, comes out at about 18 kW. I've also found the original Nu-Heat UFH design sheets, which also show around 18 kW (although it gets some rooms completely wrong, mostly as they get too hot).
Then I worked out the flow rate from the secondary pump on the internal unit, which feeds the buffer cylinder. As I don't have a flow meter, I did this by charging the buffer with the flow and return to the UFH and rads closed. I used this to recalculate the measured delivered heat by source for the 2024 - 2025 season:
 This pretty much agrees with the previous calculations in the colder bands, but diverges as it gets milder. This is a much better fit and again agrees with the gas only regression which gave around the same figure at a design temperature of -3. So the house draws around 13 kW at -3 with gains present. The 12 hour sustained peak was 13.7 kW. Adding in a margin for the coldest bin, the boiler efficiency being 90% and the house actually being heated to 23.5 C (rather too hot, I know!), gives a heat pump sizing of 16 kW delivered at A-3/W35.
Posted by: @judith
Your house ought to be more thermally efficient from its build standard so you probably won’t need 2.5 times our usage to heat it (ratio of floor areas).
Your 5 January figure, corrected by your own 5 per cent, is 169 kWh over 24 hours in 200 m2. That is 7.0 kW average, or 35.2 W/m2, at 21 C internal.
My nearest equivalent is 147 hours in the -2 to 0 band last season, at 11.2 kW. Over 571 m2 that is 19.6 W/m2, while holding the house at about 23.5 C rather than 21. That's around 1.53 W/m2K conductance for yours against 0.82 for mine.
Posted by: @judith
Your extrapolation to -3/-4 is indeed eye watering and perhaps you might consider plotting error bars on the data and slope?
I haven't done this yet, but will post again once I have!
Your energy: 7 kWh
Posted by: @jon
Posted by: @judith
R (The R Project for Statistical Computing, I use it with R Studio) can do and plot confidence intervals for regression lines but I suspect they will end up looking like a cartoon blunderbuss given the data you have. R is not for the fainthearted, but it is extremely capable, and produces very high quality plots.
It might also be worth doing a residuals plot.
I take it you are also following the Adventures in heat loss calculations thread, if not, you may want to take a look, asit has some useful stuff in it.
This post was modified 2 months ago by cathodeRay
Love this
Page 4 / 4
