Why are DNOs replacing 100A household service fuses with 80A?
Posted by: @editor…
Who knew a fuse could generate quite this much heat and debate. 😀
Just for the absence of doubt, I’m not getting heated. I am, however, getting very into the debate.
Essentially, I agree with what @jamespa is trying to achieve. I just disagree with his preferred method.
Posted by: @editorIf I need to put dinner on or heat the house, I think it’s fair to expect to be able to do that even if the neighbours are doing exactly the same thing.
Again yes I agree. Nobody should be asked to shift dinner, nobody needs to be asked to shift dinner, nobody will have to shift dinner with an 80A or even a 60A fuse unless they are doing something that is either non domestic or which could easily be delayed while dinner cooks. Its other things that can shift with little or no pain to the user, have the technology to automate the shift, and are widely quoted as the reason we need extensive network upgrades.
Posted by: @editorBut surely we should be getting to a point where the grid can keep up with the demand we’re actively encouraging
Yes absolutely, provided its used responsibly and intelligently, or if its not then the person who is not using it responsibly and intelligently pays for the privilege
Posted by: @editorI think it’s the network’s job to keep up with the things we need to do when we need to do them.
As above I agree, with the emphasis on need not want!
Posted by: @editor
it’s absolutely ludicrous that after all the investment in renewables we’re still turning down Scottish wind generation because we can’t get enough of that power to where it’s needed
I agree, but that's a separate part of the equation, we started talking about fuses which are principally about the local distribution network, not the long distance transport network
Posted by: @majordennisbloodnokPosted by: @editor…
Well I admit I threw the (rather crude) method out there in response to the title and to provoke debate, which it certainly has (perhaps more than I had expected)!
I am very conscious that there are people who do not respond to carrots such as ToU tarrifs, expect to do exactly what they want to do without care for anyone else, yet also expect everyone else to pay, and are often the people who can easily afford to pay but complain whenever they are asked to do so. A simple rule helps 'level up' and provides the stick which replaces the carrot that they wont take.
Its not unique, there are countries where the tariff depends on your max load.
Currently viewing this topic 3 users ( JamesPa, Majordennisbloodnok, AndrewJ ) and 13 guests.
Recently viewed by users: Transparent 8 minutes ago, Judith 35 minutes ago, Mars 8 minutes ago, Domino 54 minutes ago, RobS 55 minutes ago.
- 2,828 Topics
- 67.2 K Posts
- 2,197 Online
- 7,247 Members
