Why are DNOs replacing 100A household service fuses with 80A?
8 Users
5 Reactions
Your energy: 45 kWh
@jamespa, I take back what I said about not monitoring our power draw, because your last reply made me realise I have the readings in the SolarEdge app courtesy of the current clamp. With the heat pump out of action, the highest sustained draw (more than 20-30 mins) I’m seeing is around 5-6 kW. That would have been in double digits with our heat pump running, and higher still if the oven was on.
Your energy: 53 kWh
Posted by: @domino
I would hope not for larger detached properties.
Why should 'larger detached properties' pay the same for the infrastructure (through the standing charge) as a two bed semi?  If they time shift their use so as to help out with grid loading then I would accept that they should.  If they are selfish and use power when they fancy then why should they not be asked to contribute more to the infrastructure costs?
Your energy: 45 kWh
@jamespa, I can see the appeal of a local signal that tells a charger or battery to ease off when the street is under pressure, but I’m struggling with calling the Major’s load artificial when he’s doing exactly what his tariff encourages him to do. If the cheap window is a good time to use electricity nationally but a poor one for his local substation, then by all means give his equipment a way to respond to that. I’m less clear on why an 80A fuse needs to be part of the bargain, particularly for someone whose existing supply can safely support 100A. I guess that's the bit I'm struggling with.
If the charger and battery are already responding when the local network is stretched, what extra upgrade would a lower fuse rating actually avoid? I’m quite happy to shift the loads I can, but given how much we already pay towards maintaining and developing the network, I think it’s reasonable to expect it to keep pace with the ordinary demands of an increasingly electric home, including those evenings when you want the heating on and dinner in the oven at the same time and maybe an electric heater in a room that's struggling to come to temperature.
Your energy: 53 kWh
Posted by: @editor
Yes, bit unless your heat pump draws 6kW, implying 18kW load, then it wont go over 12kW or if it does only for a short time when the oven is on (which is probably when you are seeing 5-6kW anyway).  I dont know what constitutes 5-6kW but either something in that or the heat pump can shut down, without you noticing it, while the oven is on if thats whats needed to avoid or reduce massively expensive grid upgrades.
This post was modified 3 minutes ago 2 times by JamesPa
(@majordennisbloodnok)
Mitsubishi Electric
Your energy: 22 kWh
when pricing is encouraging me to take electricity, I’m generally around the 11-12kW mark even with the inverter only able to send to the battery at 3kW. If I had (as I am planning) a more modern inverter and bigger battery that would put me over the 12kW mark on just battery and EV alone. And that is sustained for several hours, not just a short blip.
Bear in mind that a 6kW inverter, a heat pump and an oven can easily get close to 12kW draw. If someone was on an Octopus intelligent tariff, the EV could easily be turned on even without the homeowner’s knowledge and push the draw way higher without any overseeing considered decision.
ok, so you are imposing an artificial load in order to time shift!  So in that case I would say that you should be allowed to do, but only at times when the grid can support it, through a locally available signal that your equipment respects.
In  return for that have an 80A fuse because, by doing this, you are doing everyone a favour.
All I am trying to do is to get people to control their usage to avoid unnecessary grid upgrades, without invoking 'big brother' control and without inconveniencing people!
I totally understand your reasoning and intention, and actually agree with you on that. My point is that the fuse doesn’t take preferred timings into account; it’s an unbending big stick and imposing it with too low a limit affects positive and negative actions alike.
Your energy: 53 kWh
No it doesnt, but a few select (eg heat pump, EV charger and battery) items can and that is sufficient.  The fuse just forces people to deploy the tech which enables these few select items to do so or, if they choose not to, to pay for the priviledge.
This post was modified 56 seconds ago by JamesPa
This post was modified 32 seconds ago by JamesPa
Page 2 / 2
