Volumiser required on Grant R290 air source heat pump?
Posted by: @patrickGreat news this week too. The heat pump grant here has increased from €6500 to €12500.
Thats generous! Does the small print of the grant allow DIY? In UK it has to be a MCS registered professional( doesn’t guarantee competence) and replacing an existing fossil fuel boiler.
If it follows other grants here, then, as before, you have to use a registered contractor. And like in the UK there is no guarantee as regards quality etc
It puts me off using grant assistance in most cases but at that level of support I will look more seriously into it.
There is one other really good scheme here for vacant homes. If the house is over 2 years not lived in then there is a max of €50k for bringing it back into habitable use. This grant does allow for DIY (with local authority oversight) so that sum can be pretty much parts only support.
@jamespa I agree that it is important to avoid a 4 port buffer or low loss header, due to the impact on efficiency.
My understanding is that volumisers should be installed on the return circuit, not the flow?
I have a Grant Aerona R290 15.5kW heat pump, which is running very nicely. Certainly don't go for the Aerona3 R32 heat pump or its antiquated controller.
I would be happy to help you with how to use the Aerona R290 Smart Controller.
Posted by: @grahamfMy understanding is that volumisers should be installed on the return circuit, not the flow?
There is a thread from a year ago where this was debated at length and the conclusion, well argued imho, was flow is better but it's likely only to make a difference in a relatively small minority if cases, and the difference will be a marginal comfort one.
@judith Indeed it's similar to the UK. It has to be an SEAI registered installer(no guarantee of competency) and the house must reach a minimum level of energy efficiency after the works are completed.
I spoke to our plumber who said he can't even install a heat pump on his own house as that won't qualify for the grant. So he needs to get another registered installer to do it.
- 732 Online
By bobflux , 21 minutes ago
By Fretless6 , 2 hours ago
By Jonatan , 5 hours ago
By bobflux , 12 hours ago
By Batpred , 12 hours ago
By Transparent , 15 hours ago
By bobflux , 16 hours ago
By Toodles , 18 hours ago
By JamesPa , 22 hours ago
By Toodles , 4 days ago
