Thermistor for a Gr...
Thermistor for a Grant QRSC180SL
2 Users
2 Reactions
(@grantmethestrength)
Does anyone know how far into the sensor pocket the thermistor goes. I.E. If I get a two metre cable how much “tail” will I have left?
This topic was modified 11 months ago by Grantmethestrength
Kind Regards
Si
Grant Aerona3 13kW
Sigenergy 10kW Inverter
16kW Sigenstor battery
The all mighty Claude AI reckons between 100-150mm but as we all know the AI’s and the 5G’s have been wrong before! 🤣
Kind Regards
Si
Grant Aerona3 13kW
@neil is this something you could advise or assist with?
Cheers @editor  I managed (with the help of a mirror) to take a look inside. If this helps anyone else (as I genuinely didn’t know) the sensor pocket is just a tube through the insulation and you just push you temp probe in, mine is about 150mm in depth, I have a little probe with a digital display in there at the minute but the NTC 10K / B3950 thermistor to connect to the heat pumps is arriving today.
Kind Regards
Si
Grant Aerona3 13kW
@grantmethestrength, Neil’s on vacation, but he DM’d me saying: “The answer to the cylinder question is 120mm. So he’ll be left with 1.88m for a 2m sensor.”
@editor awesome thanks.
Kind Regards
Si
Grant Aerona3 13kW
