Siting of the external sensor on a heatpump
My heat pump receives sunlight, so when the fan is not blowing, OAT sensor readings are hotter than actual air temp.
@jamespa Installation of gas boilers would be carried out by registered gas fitters so it would be unlikely that many consumers would question the workmanship; muppets would be able to get away with it rather than the consumer doubting the muppet’s ability. With heat pumps, I would suggest that the consumer is likely to be more enlightened and also more questioning so muppets might be detected more readily. Regards, Toodles.
@bobflux My Daikin ASHP is SSW facing and the wall behind it has cavity wall insulation; during the summer, this produced ASHP temp readings of 35 - 40 C.! I think that even in wintertime, if the sun shines for a few hours, the reading is elevated by a few degrees C. Regards, Toodles.
My Octopus electrician (part of the installer team) noted that even in April there was some sun getting through to the Daikin and asked to site the sensor on a wall in the shade. Since the way to that was under a path he did ask for a conduit which I was happy to provide.
Daikin 6Kw ASHP.
Posted by: @toodlesmuppets would be able to get away with it rather than the consumer doubting the muppet’s ability.
Our boiler came with the house.. We found all sorts of issues (like the internal thermostat was in the boiler cabinet!!) and when we tried to reach the muppet, he had moved to the next county. The gas side was probably safe, but everything else was shortcut.
Posted by: @batpredPosted by: @toodlesmuppets would be able to get away with it rather than the consumer doubting the muppet’s ability.
Of course had the heat source been a heat pump it would all have been the fault of the heat pump not the muppet who installed it, but just as we dont talk about muppets installing boilers, we dont talk about the faults they leave nor assign them to 'the boiler'.
That doesn't excuse these faults of course, but it does put them in context by confirming that muppets work on boilers and leave problems behind just as they work on heat pumps and leave problems behind. In neither case is the technology at fault, the fault lies with the muppets.
Absolutely. Even if the same mistake was made with the boiler, this is no excuse for the heatpump installer. I just told them that I do not consider it urgent and that I do not care whether they shield it or move it.
- 2,828 Topics
- 67.2 K Posts
- 3,901 Online
- 7,247 Members
