[Solved] Repiping Volumiser tank
I intend to replace the Plex pipework in the area of my volumiser tank.
I now realise that the contractor who changed it from buffer to return line volumiser, used too many Plex elbows with the result that potential flow was significantly limited.
I will take the opportunity of putting the tank in the flow, but have 2 options for piping as the diagram.
Option 1 gives diagonal flow across the tank but will require more elbows/ bends.
Option 2 is the easiest and minimises elbows/ bends, but has inlet and outlet on the same side of the tank.
I would welcome views on which is the better option.
2 x Growatt 7.5kW Batteries
Fronius EV Charger
Kia e- Niro 64kW
Without a detailed analysis of the hydrodynamics I would say it's impossible to say but unlikely to make a great deal of difference. I can't see much chance that the tank somehow divides itself into two on a vertical plane in 1 so I would expect that most of the eater will be engaged. It's gut feel I admit with a tiny bit of handwaving science.
- 2,828 Topics
- 67.3 K Posts
- 4,164 Online
- 7,249 Members
