New Build ASHP Defects - Looking for Advice, Support & Shared Experiences
Thanks,
That’s really useful. I’ve got the Daikin MMI controller and will increase the WC curve to 55°C @ -3°C on the next cold spell. I’ll log room temps, flow/return, outdoor temp and energy use as suggested and report back with results.
Just waiting for NHBC to get back so will give it a go.
Posted by: @newbyThanks,
Should be interesting. Do watch to see if the UFH gets too hot, although if it does then thats a positive outcome!
Thanks for the detailed thoughts, that all makes sense. I’m going down the formal route for now, but I’m trying to understand the system better in the meantime, so I’m not caught out when someone eventually turns up. I don’t have all the technical info yet because some of what I’ve been told came from a handyman who had a quick look, but I’ll get firmer details as I go. I’ll also try the 55°C flow test on the next cold spell to see whether it points more towards the rads or the heat pump.
On your specific questions: the primary pipework looks like plastic, roughly 22mm, with 15mm plastic to the rads. The COP figure of around 2 was just a rough comparison between the heat pump’s reported output and the electricity used on the coldest days. As far as I can tell there’s no buffer, LLH or plate heat exchanger in the system. I’ll start logging proper data now and will post whatever I can, including the thermal images. I agree the insulation needs sorting first, that’s already in motion and hopefully once that’s fixed the rest will be easier to pin down.
Thanks for all of that is really helpful context. I agree that if the house can’t get above 16°C in cold weather with a 7 kW unit, then something fundamental isn’t right, and the insulation/air‑tightness side is looking more likely. I’ll definitely follow up with Building Control as you and @transparent suggested, especially around the insulation evidence and whether the application fell before or after the photo‑requirement change. I’ll also ask what they hold on file in terms of plans, SAP and the under‑screed build‑up, because none of that has been provided by the builder.
On the heating side, the floor and rads aren’t getting above room temperature during cold spells, which lines up with what you’re saying about heat loss. Your comparison with your own builds really highlights how far off things are here, even with modest flow temps you’re getting stable indoor conditions, whereas mine drops away quickly. I’ll take proper surface readings and keep gathering data, but at this point the insulation route looks like the first thing that needs resolving before anything else can be sensibly assessed.
Thanks, this is extremely helpful, especially the explanation about NHBC pre‑registration and older SAP/Building Regs potentially being the standard my plot was assessed against. I’ll be asking for the full SAP printout so I can see exactly which edition was used and whether the design assumptions match what’s actually been built. That alone could explain why the theoretical performance looks fine on paper while the house can’t hold temperature in reality.
I’ll also follow your advice about contacting the LPA directly. I hadn’t appreciated that they still hold the enforcement powers even when NHBC handled the inspections, so I’ll put everything in writing with photos and diagrams so the Councillors can see the issues clearly. The commissioning requirements you’ve highlighted from Part L are another gap, I’ve only been given generic manuals, nothing site‑specific, and certainly no commissioning plan or completion notice. Combined with the insulation defects already identified, it’s becoming clearer why the system is struggling.
I’ll start pulling all of this together into a proper evidence pack. Thanks again for taking the time to set this out so clearly, it’s given me a much clearer route forward.
Posted by: @newbyOn your specific questions: the primary pipework looks like plastic, roughly 22mm
Is that a single pair only? If so it may be part if the problem. How long? What flow rate do you have ( your heat pump will tell you) and what dt flow to return (again your heat pump will tell you).
- 2,539 Topics
- 59.1 K Posts
- 911 Online
- 6,818 Members
By JamesPa , 24 minutes ago
By JamesPa , 1 hour ago
By Boycey , 3 hours ago
By ChandyKris , 4 hours ago
By JamesPa , 6 hours ago
By Papahuhu , 6 hours ago
By Majordennisbloodnok , 7 hours ago
By TechnoGeek , 7 hours ago
By Gruff2001 , 10 hours ago
By Papahuhu , 10 hours ago
By antonical , 12 hours ago
By Mars , 12 hours ago
By JamesPa , 13 hours ago
By RobS , 1 day ago
By antonical , 1 day ago
By Boycey , 1 day ago
By Judith , 1 day ago
By antonical , 2 days ago
