From Auto adapt to W/C Ecodan
Iv been on auto adapt mode using the timer but im currently try to switch the system to W/Comp.
Every time the timer cuts in the system automatically reverts back to Auto adapt mode.
Does the ecodan not allow a timer setting on W/comp???
When on WC the WC curve controls the heating based on the outside temperature. You can use schedules for DHW (hot water) though. What are you trying to do with a timer?
Apologies Rob as I now understand what you were saying concerning the w/c controls the inside temperature depending on the outside temperature.
So does that the make my wireless controller in my living area redundant other than acting as a temperature gauge 🤔
Almost, the wireless controller just becomes a limiter, if the internal temperature goes 1C above the set temperature then the heat pump will be shut off until the interval temperature drops below the set temperature +1C.
- 453 Online
By bobflux , 13 minutes ago
By Renewables345 , 1 hour ago
By benson , 1 hour ago
By cathodeRay , 3 hours ago
By bobflux , 3 hours ago
By bobflux , 4 hours ago
By Jonatan , 8 hours ago
By bobflux , 15 hours ago
By Batpred , 15 hours ago
By Transparent , 19 hours ago
By bobflux , 19 hours ago
By Toodles , 22 hours ago
