Ecodan FTC6 DHW tim...
Ecodan FTC6 DHW timing etc
2 Users
0 Reactions
(@davidalgarve)
I am again trying to optimise my DHW settings taking into account my 2 part tariff, large power demand, (even on "Eco" setting) and any possible contribution that might be available from 4kW solar.
In this regard, could anyone explain the meaning and possible setting for "Mode Restriction" and "Recharge"?
I note that in the case of the latter it is set on "Large" and there doesn't appear to be an alternative
2 x Growatt 7.5kW Batteries
Fronius EV Charger
Kia e- Niro 64kW
 F1p
(@f1p)
Mode Restriction
For ease, let's assume you have no schedule and hot water runs purely on meeting the temperature drop parameter
Say you have just finished running hot water up to setpoint and then you run a bath, immediately dropping the temperature back down
As Hot Water takes priority over heating, this duration will block the unit from starting the hot water re-heat immediately, but wait the duration of this timer to give some time allocated to Heating.
Recharge
My understanding is by selecting "Large" it gives the ability to utilise both an Upper and Lower Hot Water tank Thermistor (THW5A and THW5B) - typically installed on 250li or larger tanks
For "Standard" only one Thermistor is installed (THW5B) - typically for tanks under 250li
(@davidalgarve)
@f1p Thank you very much for the information - most useful!
Regarding “Recharge”, I only have one thermocouple fitted and it is in the lower socket now, but I believe a recent contractor repositioned it to use the upper one for a ground connection!
Would the FTC6 automatically sense a second thermocouple, or would it be a dip switch setting? It would be quite useful to have the option.
As it is currently, there is no facility to change this setting.
Fronius EV Charger
Kia e- Niro 64kW
 F1p
(@f1p)
@davidalgarve
I have never made a conversion from standard to large personally, I presume you Service > Thermistors page already shows THW5A (upper sensor) option
I don't see any references in the FTC manual regarding dip switches for this option so I suspect it's done in software at that Recharge menu option
