Daikin 8kw Monobloc not switching off when room thermostat exceeds set point
We get huge amounts of solar gain.
I had the Maduka room thermostat installed in the sunniest room to act as a limiter if we start to overheat.
We are running on WC and have set the thermostat to 22c. So if we go above 23.5c I'd expect the HP to shutdown.
On low solar gain days the house ticks along 24/7 around 21c constant. Perfect.
Today we have hit 26.5c on the thermostat, the whole house is very toasty and I expected the HP to shut down, but it hasn't.
What settings might need changing so the thermostat does it's job?
Thanks.
Recently viewed by users: trebor12345 28 minutes ago.
- 2,505 Topics
- 58.1 K Posts
- 345 Online
- 6,237 Members
RE: Any thoughts on control strategies for heat pumps?
By Travellingwave , 6 minutes ago
RE: New Solar, Batteries, Air Source and Under Floor Heating advice please
I thought my 12kW solar installation was overkill until...
By bobflux , 20 minutes ago
Transparent thank you for your reply. I will go ahead ...
By trebor12345 , 24 minutes ago
@n1ckw Just a thought, if you are taking in from the gr...
By Toodles , 57 minutes ago
We get huge amounts of solar gain. I had the Maduka r...
By Bash , 1 hour ago
It has been said that both manufacturers and installers...
By JamesPa , 2 hours ago
Hi all. I have made some progress regarding cause of cy...
By Tasos , 3 hours ago
RE: Need some help with choosing the right Rads
Wow, thats a big (or very poorly insulated) bathroom. ...
By JamesPa , 4 hours ago
Monty Python may have asked 'what have the Romans ever ...
By cathodeRay , 6 hours ago
RE: Knock on effective of balancing radiators
Decorators caps, not screwed down (they can actually be...
By JamesPa , 6 hours ago
@craigh Hello, I had best explain how my Homely control...
By Toodles , 7 hours ago
I'm not so sure that the rest of society values a maths...
By JamesPa , 21 hours ago
Thanks a lot GC61 - I'll open a separate thread in due ...
By Kev1964-IRL , 23 hours ago
RE: The Hidden Secret to a Successful Heat Pump: Pipe Size Matters
@falesh having a house of similar age the two issues I ...
By Terry1812 , 23 hours ago
RE: Our Experience installing a heat pump into a Grade 2 Listed stone house
Remember that the house continues to lose energy when t...
By JamesPa , 24 hours ago
@editor I'd missed that, and it's a very good response ...
By Sheriff Fatman , 1 day ago
There has been quite a bit of discussion (mostly on OEM...
By MartinRobinson , 1 day ago
@af1 My EPC rating jumped from E to C after installatio...
By dr_dongle , 1 day ago
@odd_lion the minimum MCS requirement is 2.8. I don't...
By benson , 1 day ago
RE: Advice on potential HW Cylinder size
I think the comment about heating from cold is quicker ...
By sjcsystems , 2 days ago
RE: Ideal HP290 14kW ASHP - how to optimise
Hi You can get a stethoscope for less than 10€ on Ama...
By bobflux , 2 days ago
Your DT is to low, you do not have enough heat exchange...
By ASHP-BOBBA , 2 days ago
I am aware. But is your chart direct from a Pace BMS ap...
RE: Call for heat on open loop weather comp system
I don't know Grant system but most ASHP are very simila...
