A2A vs A2W: Which Heat Pump Would You Pick?
Posted by: @springswoodAn ounce of experiment is worth a pound of theory.
Love that!
I also value real world feedback from the most demanding users.
A thought: how large could an airbnb with a simple a2a heating system be and still survive a real world rating from its customers? Also a great testbed for the controls..
Posted by: @deltonaPosted by: @etchedpixelsDefinitely air to air (and we did)
We have a big solid stone 1860s victorian pile with 18" thick solid walls. It's grade II listed so a lot of insulation is simply not possible and would wreck the building.
Why do you think it impossible?
Because both the inside surfaces and outside surfaces of the walls are of historic value. We looked at insulation. There are things that can and have been done like magnetic secondary glazing but the walls, floors and some other elements of the structure are not really improvable in a way that would get LBC.
Posted by: @springswood@jamespa That's interesting and would bring cost down a lot.
I realise what's holding me back is that without experience I have no feel for how warm air heating will spread through a house.
There's a saying I picked up when studying physics. An ounce of experiment is worth a pound of theory. It was a long time ago. So if it was the winter I'd play around with a couple of fan heaters to see what positions might work. Maybe I'll be better off waiting...
On the ground floor there's the living room and kitchen. Would heat from the living make it to the kitchen or would it escape up the stairs, which can't be closed off?
Upstairs is probably OK for heating. Just one bedroom and the bathroom. I can see heat spreading there OK. Up to the spare bedroom in the attic as well.
Would the attic be cooled by a unit on the floor below though? I imagine not and naturally it overheats most (and gets used maybe 20% of the time).
So much of this depends on the building. A unit at the bottom of the stairs will slowly warm the upstairs in my experience and heat will usually spread through a building nicely. How fast and where though depends on what the walls are made of (eg it's much slower to heat/cool with real internal walls than bits of plasterboard and stud). On old old houses with big solid internal walls you really don't get much through the walls unless you are maintaining a temperature steadily for a very long time.
Cold air falls, so it's not going to affect the attic much if you are not feeding cold air into the attic. If the attic is being cooked by the sun through the windows and the roof then it's not going to help. If it's being cooked by heat rising from the rest of the house then maybe.
Best thing I know for cooling an attic room is to put solar panels over it 😉
Fan heater experiment sounds a great idea.
Posted by: @etchedpixelsPosted by: @deltonaPosted by: @etchedpixelsDefinitely air to air (and we did)
You can't put EWI on without changing the aesthetics of an un rendered building, but can a rendered one. So one is Listed building friendly, the other not.
IWI and floor insulation on the other hand doesn't change the way a building looks so can be done. Granted it's messy, expensive and risky*, but you haven't sited those as reasons.
* You do need a good system and someone who really knows what they're doing to fit it. Like with ASHPs, not a common thing.
Posted by: @deltonaPosted by: @etchedpixelsPosted by: @deltonaPosted by: @etchedpixelsDefinitely air to air (and we did)
I tend to have a problem with absolutes, @deltona.
Yes, there are situations where EWI can be added without changing the aesthetics of a building. That doesn't mean it is listed building friendly, it means it may be.
Similarly, IWI and floor insulation do not, as you say, change the external look of a building, so they may be allowable but it's not a guarantee.
@etchedpixels specifically said that both internal and external faces of the walls in this case are of historic value, which implies his assertion that insulation is not possible is being made from a position of knowledge rather than assumption. I would personally not have a problem with firing "have you considered this?" questions towards @etchedpixels but I think you're probably on dodgy ground to be stating that he's wrong and that something can be done without anything more than what's been written on this thread to go on.
- 2,815 Topics
- 2,703 Online
- 7,230 Members
By EtchedPixels , 7 minutes ago
By JamesPa , 10 minutes ago
Sorry, gents, I wasn't supposed to drop a comment and t...
By Pirate Rich , 25 minutes ago
@brazilguy67, glad you've managed to get someone to hav...
By Mars , 2 hours ago
We've had an influx of new members joining the forums o...
By Mars , 3 hours ago
By Chilli304 , 4 hours ago
By JanHarley , 5 hours ago
By JamesPa , 8 hours ago
By bobflux , 21 hours ago
By bontwoody , 3 days ago
