Aircon is aka air to air heat pump so, as with air to water heat pumps, they're highly efficient. Getting 3x kwh out for each kwh in. Ehether heating or cooling
So useful for aircon in summer - especially if you have solar and/or batteries to fill at cheap overnight rates.
Aircon is also useful as heating in the shoulder months when your ashp may not really be needed. Even better with solar/batteries.
LG Therma V 16kw ASHP
Underfloor heating + Rads
8.7kw pv solar
3 x 8.2kw GivEnergy batteries
Manual changeover EPS
MG4 EV
@papahuhu I think that accessibility issues go in waves, then poly tishuns get tired or change / money gets even tighter and things drop off again. Local buses are my mainstay but even those are threatened periodically and we have to fight again. Toodles.
- @papahuhu And another ‘Mega’ month and, the best August in 4 years. (Aug. 2022 was not logged with my Tesla Kit as it was not commissioned until November 2022, though the system was running with just the Enphase system logging details that started sometime in that August).
Regards, Toodles.
Very nice.
Ours was the opposite, about 10% down on mean for August.
Finally won my battle with the insulation remediation firm that implemented my retrofit and getting SWIP internal room in roof insulation fitted tomorrow, on the main roof. I requested a trustmark audit and they confirmed the necessary remediation, free of charge. Going to be interesting to see what it does to my heatloss, Im hopeful it will bring the flow temp down a few degrees. The other roof I had similarly done resulted in me turning one of the 3 rads completely off. I didn’t know if it were better to leave the others fully open loop and close one, or back all of them off via the TRVs.
Ours was okish, still did better than last year August. We generated a little over 500 kWh. But, with the savings sessions, free weekend electricity, we ended up with a negative bill. Not complaining!!
16 * 435 watts PV
13 kWh Growatt battery
1 EV - Mercedes EQB
6 kW Aira Heat Pump
Bosch Induction Hob
Pod Point Solo 3 charger
Possibly useful to look at 3 months Jun, Jul, Aug and compare with previous years
2026: 2635kWh
2025: 2271
2024: 2239
2023: estimate 2140 including 15 day outage
2022: 2126
8.7kw pv solar
MG4 EV
Tim, do you mind if I ask how much power does your heat pump consume in a year please?I have a similarly sized 16kW unit and wonder if my annual consumption is atypical at 7MWh. It’s less than the 10 that was predicted by MCS calcs but it still feels a lot when Im trying torun it on the lean side of comfort.
@papahuhu I have pretty good data. Notes:
100sq m is very old listed building
100 sq m is modern extension
First 2 years ran on fixed flows 55deg. After that weather compensation with aggressive low flows but main living areas 21deg. Other areas much cooler. Installed 2020. Exact monthly data from 2023
2021: 8050kWh
2022: 8050
2023: 5782
2024: 5741
2025: 5756
Showing importance of weather compensation. Added to batteries and Intelligent Go the costs are transformed.
Ave import price last year 9.1p
8.7kw pv solar
MG4 EV
3 months ago
2 years ago
3 years ago
First 6 months
4 years ago
Currently viewing this topic 26 guests.
- 2,815 Topics
- 2,325 Online
- 7,230 Members
@bobflux - is Trinnity what the Catholic Church in Fran...
By Transparent , 1 minute ago
Wow, an appliance can be smarter than the manufacturer ...
By Batpred , 3 minutes ago
By Toodles , 2 hours ago
By EtchedPixels , 2 hours ago
By JamesPa , 3 hours ago
By Chilli304 , 7 hours ago
By JanHarley , 7 hours ago
By JamesPa , 10 hours ago
By bobflux , 24 hours ago
By bontwoody , 3 days ago
