Season’s Greetings
We're thrilled to share that Renewable Heating Hub has hit record numbers this year, all thanks to you!
Thank you for your continued support. May your holidays be merry, and the New Year bring you warmth and sustainability.
Happy Holidays and Cheers to a Bright 2024.
Same to you. Thanks for providing this forum for people to learn from and to teach each other. Here's to a higher COP and a lower energy bill in 2024!
Grant Aerona 3 10kW
Same to you Mars and all readers of this hub, may your scop’s rise evermore and may the heat pump crackling logs keep you all warm and cosy (though @ temps. of 10 - 12 degrees C, our pump is resting most of the time!) Happy Christmas and a warm new year to all. Regards, Toodles.
- 815 Online
I agree incentives are needed. We are an unusual home b...
By Batpred , 49 minutes ago
@tasos interesting. I might look into that. My other op...
By benson , 2 hours ago
RE: Our Experience installing a heat pump into a Grade 2 Listed stone house
@robs Do you need IAT for this to work? Don’t curren...
@goodbyegas Hi Fellow Ecodan owner here. Looking a...
By Travellingwave , 5 hours ago
You can send private messages via the Messages (envelop...
By cathodeRay , 8 hours ago
With complete radio silence from Peak and no sign of th...
By DaveC , 8 hours ago
Yes, ours dropped by about 25% RH. I figured it was a c...
By Papahuhu , 10 hours ago
RE: The Hidden Secret to a Successful Heat Pump: Pipe Size Matters
I'm wondering if I need to do any pipe upgrades. My hea...
By Falesh , 10 hours ago
@batpred The Pace BMS also isn't the best with it's ...
By Bash , 10 hours ago
I understand now what you were referring to. This look...
By trebor12345 , 10 hours ago
@batpred I would consider changing your balance star...
By Bash , 11 hours ago
This illustrates what I am getting at, even apparent st...
By cathodeRay , 15 hours ago
No you arent, because you dont need any, and furthermor...
By JamesPa , 16 hours ago
As I mentioned earlier most radiators have a power outp...
By JamesPa , 17 hours ago
By cathodeRay , 1 day ago
By DavidB , 2 days ago
By Slartibartfast , 2 days ago
By Papahuhu , 3 days ago
By Bash , 3 days ago
