Maximising Home Aut...
Maximising Home Automation: Integrating Octopus Energy & More
4 Users
9 Reactions
(@majordennisbloodnok)
Topic starter   [#1645]
wpf-cross-image
In this fourth and final article on home automation, I’m going to see where and how the system we’ve built so far can be extended to get all your kit working more cohesively and, hopefully, reap some real efficiency benefits as a result. I mentioned in the last article that this one would be a bit of a marathon since there’s a lot to get through, so you might want to take a break for a well-earned cuppa halfway through.
Recapping, we’ve already set up Home Assistant and installed several integrations for interacting with various things; in my case, we have a solar generation forecast service, a Melcloud integration allowing me to link with the Ecodan heat pump, and a Growatt integration for doing the same with the inverter and battery. The first two are pretty solid and performing as expected, while the web service that the Growatt integration tries to communicate with is less than dependable for various reasons. Moreover, the Growatt integration allows a reasonable range of monitoring but precious little ability to change settings.
This leaves us with some jobs still to do:
  • We need to incorporate my Octopus Energy agile tariff information (import and export), but there is no out-of-the-box integration for that.
  • We need a better way to manage the Growatt inverter and battery.
  • We need to start configuring Home Assistant to make some automated decisions based on the data we’re gathering—after all, that is rather the point of this whole exercise!
Custom Integrations
As I touched on in the last article, each integration is just a small package of code allowing Home Assistant to talk with stuff. If the Home Assistant developers (or manufacturers wanting their kit to integrate easily) haven’t provided an integration for the kit you want to talk to, it’s perfectly possible to write your own integration and there is a VERY good chance someone has already done so. In fact, Home Assistant encourages this and provides what it calls the HACS (Home Assistant Community Store) as a place where you can find third-party-developed integrations and, if you’re techie enough, offer your own.
This is exactly what I need to get Home Assistant talking with Octopus Energy since they provide a web service—an API—but no in-house Home Assistant integration, meaning we’ll need to use a custom one. Going to the left-hand-side button bar and clicking on the HACS icon takes me to a screen where I can search for “Octopus”; I’m going to pick “Octopus Energy.” Clicking on it takes me to a page which starts to look worryingly techie, but in amongst it is the information about how to install it. Even better, it splits those instructions in two, the first part being how to install via HACS and that is little more than “click on the ‘Download’ button in the bottom right-hand corner of the screen.” The Download button gives me a quick popup telling me stuff and reminding me to restart Home Assistant after downloading, and I just follow the instructions. Once the download has finished, I am able to click on the Settings cog on the left-hand button bar, and the ensuing screen tells me a restart is required, so I click on that and it restarts Home Assistant.
HA OE
Bear in mind that all this has done is update Home Assistant to know there is another integration that can be used, but it hasn’t actually told Home Assistant to use that integration. In effect, we’re at the starting point we’ve seen before for adding standard integrations, so we can now add the Octopus Energy one in the same way as we added the Melcloud one or the Solar Forecast one in the previous article. So now we’ve done all that HACS stuff, when we click “Add Integration” on the devices and integrations page, we can now search for and find the Octopus one. Obviously, it asks for a different set of details that are Octopus-specific (an account ID in the format of A-XXXXXXXX that you’ll see on your Octopus dashboard, an API key that you can find by burrowing into My Account/Personal Details/Developer settings (API access button) and perhaps a tweak or two of the odd optional setting but probably not), but you fill them in and Robert’s your mother’s brother. In my case, since I have two tariffs with Octopus, the integration discovers two devices (one import, one export) and a load of entities in each.
Now I could click into each device and add the various entities to my dashboard as we did in the last article, and that’s the way I’ll leave it for now. However, there’s a lot to take in with all that info, so I got a bit clever—or at least took advantage of someone else having done so—and also installed an Octopus Energy Rates Card. It does involve a bit of configuring that isn’t just clicking on buttons, but I think it’s worth it. Just bear in mind that it doesn’t affect the automation and decision-making that relies on the Octopus data, but the benefit it provides is easier reading of that data. If you want more information about how I did it, head over to the appendix for more detail, but for now, we’ll ignore it.
Now for that inverter. Perfectly solid bit of kit, not good cloud or app management capability. For those who have been regulars on the Renewable Heating Hub Forums, you’ll probably have already guessed the answer I came up with: modbus. This all feels very much outside the comfort zone of the uninitiated, and the process is an exercise in jargon overload interspersed with a heavy dose of acronyms, so I’ll deal with the process of modbus itself in the appendix later—especially since it’s a hardware topic rather than a home automation topic and I don’t want it to confuse matters. From a Home Assistant point of view, though, it just needs to know it can talk modbus with my inverter via one route or another, so our steps are as follows:
  • Set up a way of talking modbus to my inverter as outlined in detail in the appendix.
  • Add another HACS integration to my Home Assistant box, this time for SolaX Inverter Modbus.
  • As we’ve seen before, I now need to go to my Devices and Integrations page and add the SolaX integration. This gives me a dialogue box asking for some pertinent details; specifically, I need to choose the interface to be TCP/Ethernet since I am using a modbus to ethernet converter (full details in the appendix), the modbus address of the inverter to be 1, and the inverter type to be Growatt. When I submit that, it asks me for the IP address of the modbus to ethernet converter and (big gotcha that had me head-scratching for quite a while) the modbus TCP variant needs to be set to Modbus TCP (not Modbus RTU over TCP, which you might have thought would be necessary having read the config stuff in the appendix). Hitting the second “submit” button adds the integration to the list we’ve been building up.
If the hardware stuff has been set up correctly and the converter is reachable on the network, then Home Assistant will now be using the SolaX integration to talk via modbus every 20 seconds with my Growatt inverter without having to talk to Growatt’s cloud services at all. In fact, now I have been running with this way of communicating with the inverter for several months, I have found it has not missed a beat. The Growatt hardware is plenty solid enough and does as it’s told reliably even when the Growatt web portal is suggesting the inverter is offline. Bliss.
Automations
At this point, I am now able to use Home Assistant to pick up a bit of forecasting, control my heat pump, get lots of Octopus info, and control my inverter. All the bits of the puzzle are now manageable in one central place, and that’s all well and good, but if I’ve just swapped several management websites for one single central one, then that’s not much benefit for quite a lot of time and effort setting all this up. In order to make the most of it, therefore, what I now want to do is start putting some automated decisions in place. Home Assistant calls those Automations. Automations are simply rules that can do things if and when things change. You may also have heard of the term IFTTT (If This Then That), and that is a surprisingly accurate explanation.
In my case, now I have a reliable and comprehensive enough ability to send my inverter instructions (thanks, modbus), and now I am receiving half-hourly pricing from Octopus, I want to get a bit more clever. What I would like to achieve is:
  • If a half-hour has a negative price, then I want to tell the battery to charge from the grid.
  • I also want to tell the battery to stop charging from the grid if the price goes positive.
  • Just because I’m cautious and know the 4 pm to 7 pm stretch is always the expensive part of the day, I want to have a safety net of ensuring the battery is not charging from the grid once we get to 4 pm.
Clicking on the cog on the left-hand button bar, I get to the now familiar Settings page. This time I need to go to Automations and Scenes where I can click the “Create Automation” button in the bottom right-hand corner. This gives me a dialogue box where I can choose Create new automation and that brings me to a new page that is actually fairly self-explanatory. There are three sections; “When,” “And if,” and “Then do,” and each section is exactly as it says on the tin. “When” is where I can say what I want Home Assistant to look out for (i.e. what is going to change), “And if” is for extra things I want to check for, and “Then do” is what I want to happen if the thing I’m looking out for happens and the extra checks are true.
So for my first automation, I’m going to tackle the question of charging the battery when a plunge price comes along, and to do that I first need to understand how to tell the inverter to charge from the grid if I’m using the manufacturer’s own systems. The more complex the manufacturer makes it, the more settings my automation has to change, but at least I only have to do it once. In my case, the inverter has multiple “modes” to give load, battery, or grid the priority, and each operating mode has multiple time slots which control when a particular mode can be enabled. To tell the inverter to charge from the grid, I need one of those time slots to cover the time needed, I need to enable that time slot, and I need to put the inverter in “Battery first, charge from grid” mode. Phew!
So to automate this, in the “When” section of my new automation, I’m going to add a trigger and pick “Device” because I want to look out for when something about Octopus changes. I then choose “Electricity Meter” from the Device dropdown, and then, in the Trigger dropdown, I select Current Rate Electricity (my ID) money changes. In the “Below” box, I can type 0 because I only want the automation to trigger if the price has changed AND it has gone below zero.
Now I can move to the “And if” section, and here I’m going to check whether or not the battery is already charging from the grid (the plunge price might have changed from -1p to -2p, in which case I don’t want to give the battery an unnecessary instruction). So here I add a condition and select “Device.” The device I choose is Growatt, and the condition I choose is “Current Growatt Battery First Charge From Grid selected option.” The option is then set to “Disabled,” meaning I’m asking Home Assistant to find the inverter, check its “battery first charge from grid” setting and see if it’s disabled.
Finally, I can look at the “Then do” section. This is what I want Home Assistant to change and in what way when the trigger(s) in “When” are activated and everything I listed in “And if” is true. So I can:
1. Click “Add Action” and select “Device.” I can then pick Growatt as the device, and in the action select “Change Growatt Battery First Time 1 Begin option,” finally choosing the option value of “00:00.”
2. Repeat step 1 but with the action “Change Growatt Battery First Time 1 End option” and set it to “23:59.” Strictly speaking, both these first two only need to be set once, but it’s not a big deal.
3. Repeat step 1 and select the action “Change Growatt Battery First Time 1 option” and set the option to “Enabled.”
4. Repeat step 1 and select the action “Change Growatt Battery First Charge From Grid option” and set the option to “Enabled.”
Now I can hit the blue Save button in the bottom right-hand corner of the screen, give the automation a sensible name, and I’m done. Now, when the half-hourly price changes and the new price is below zero, and if the inverter’s “Battery First Charge From Grid” setting is disabled, then the automation will set the relevant time slot’s begin and end times to the earliest and latest possible times, it will enable that time slot, and then it will enable the option for the inverter to charge from the grid. A lot of changes for a very specific set of circumstances all wrapped up into one rule that I can now leave and largely forget about.
Obviously, I need to go through a similar set of steps for telling the inverter to stop charging from the grid if the price goes positive, and yet another rule for stopping it charging from the grid in any case when the time gets to 4 pm, but they are all understandably variations on the same theme. In fact, in my case, once the time slot’s begin and end times have been set, then they don’t need to be set back again; I can just enable/disable the time slot as I need. The only reason I included it in one of the automations is that it’s easier to set it here than navigate through Growatt’s app.
Wrapping it up
So here we have it. In this series of articles, I have walked you through choosing a home automation system, installing the one I chose, incorporating bits of kit to manage, and then using some automations to pull the whole lot together. It’s not a small task, especially when you consider how complex any one of your bits of kit is to manage, let alone all of them together, but if you want a cohesively controlled home, then it’s necessary either by you doing it or by paying someone to set it up for you.
Has it been worth it? That’s a difficult question to answer simply. If I had had to account for my time in monetary terms, then it would have been difficult to justify a return on investment. However, my choice of home automation system was free, and even if I had had to pay the sub £100 for a preinstalled box, then my only outlay would have been the modbus network converter that wasn’t strictly speaking a home automation issue. In any event, the system has given me a single place to see what’s going on, cut out a troublesome third-party app, enabled me to make decisions about bits of my system that are based on changes in completely different areas, and incidentally has allowed me to extend far beyond just energy generation and home heating. Now I have a solid platform, there are a world of other innovative ways I could set things up (e.g. if I put the heat pump into holiday mode, tell any smart lighting and CCTV monitoring to start doing their “no-one’s home” routines). Overall, I’d say the small actual outlay is a very small price for getting my home working as I want it to.
Hope you found this series of articles useful and, if so, keep an eye out in case I follow up with further related ones focusing on related spin-off topics.
Bonus Tips
Adding the Octopus Energy Rates Card
If you decided you wanted an easier way to view the Octopus data, here’s the way I used another extra for Home Assistant; the Octopus Energy Rates Card. To make it available, I’m going to go back to HACS and do another “Octopus” search, this time finding the Octopus Energy Rates Card. As before, I can hit the “Download” button and add this new integration as the page tells me to. Once I have done so, it is available for Home Assistant to use but still needs to be configured.
In this case, the instructions also tell me some steps I need to take for a bit of configuration and this does indeed require a bit more rolling up of sleeves, but once we’ve gone through it you’ll see it’s far less complicated than it first looks. The important thing, though, is that there are several lines of text that we need to keep handy for copying/pasting, and those are detailed in the configuration section of the page we’re on. However, I’ll provide it further down this page as well just in case you lose your place.
There is also a quick bit of preparation we’ll need to do and that is to find our “Octopus ID”. In fact, it’s a combination of two bits of info that you can find in your Octopus dashboard, so let’s do that first. If we open a browser window and log onto the Octopus Energy site as we normally would and go to “My Account”, we can scroll down the “Home” section to find our tariff(s). In the white box(es) we should see two fairly long numbers; first is our MPAN and that will be a 13 digit number. I have an import and an export tariff, so I see two white boxes and each white box has a different MPAN listed. The second important bit is the serial number of the smart meter, and that will be the same for any and all tariffs listed. My “Octopus ID”, therefore (as required for the card) is the meter’s serial number followed by an underscore character followed by the MPAN number. As you can see, I have a different “Octopus ID” for my import and export tariffs.
Now I’ve worked out what my IDs are, what the configuration asks me to do now is as follows (with added hints from me to remove some of the assumptions being made):
  1. Go to my dashboard, look in the top right hand corner of the page and click on the little pencil icon. This will put the page into an “edit” mode.
  2. In the bottom right hand corner of the page, click on the “Add card” button. Scroll down to the bottom of the dialogue box and you’ll see your new “Custom: Octopus Energy Rates Card” entry. Click on that.
  3. The dialogue box will now show two boxes; the left-hand one is one you can type in, the right-hand one shows you what the result will be. Currently the right-hand one rather alarmingly shows a warning and a red background. Worry not. What you need to type (or copy/paste) is what was in the configuration part of the instructions we were given for the Energy Rates Card, but adding in your Octopus ID in where it asks for it.
    In case you didn’t make a note of it before, below is my version of the necessary text and I just need to replace (ID) with the import ID I calculated before:
    type: custom:octopus-energy-rates-card
    currentEntity: event.octopus_energy_electricity_(ID)_current_day_rates
    pastEntity: event.octopus_energy_electricity_(ID)_previous_day_rates
    futureEntity: event.octopus_energy_electricity_(ID)_next_day_rates
    cols: 2
    showday: true
    showpast: false
    hour12: false
    title: Agile import rates
    mediumlimit: 20
    highlimit: 35
    cheapest: true
4. As you can see, if I’ve done it correctly the right-hand box now looks much less alarming. Click “Save” and the card is now on your dashboard.
5. Since I have an export tariff too, I can repeat the steps to add another card but with some slightly different choices for the configuration text as below
currentEntity:  event.octopus_energy_electricity_(ID)_export_current_day_rates
pastEntity: event.octopus_energy_electricity_(ID)_export_previous_day_rates
futureEntity: event.octopus_energy_electricity_(ID)_export_next_day_rates
cols: 2
title: Agile export rates
exportrates: true
showday: true
showpast: false
hour12: false
lowlimit: 0
mediumlimit: 8
highlimit: 15
cheapest: false
and instead of using my import ID I use my export ID (i.e. the one with the other MPAN).
    With these cards added, I now have a pretty user-friendly representation of what’s happening with my agile half-hourly rates. Given the medium and high limits I chose, any half-hours with an import price above 35p will show red, any between 20p and 35p will show as orange and any below 20p will show as green. It will also highlight the cheapest half hour with a lighter green. If I see any plunge pricing (a negative price) then those slots will show as blue. Similarly, on the export card the same logic applies but is reversed so any slots above 15p will show as green, any between 8p and 15p will show as orange and any below 8p will show as red.
    In both cases, it will show the current slot and all future ones, so I see a steadily diminishing list. At around 4pm (ish), when Home Assistant gets the next day’s half-hourly prices, the cards get longer and the whole cycle starts again. Easy to read some really useful information at a quick glance.
    Setting up modbus
    Most heat pumps, inverters and similar kit are designed to be controlled by a very low level protocol called modbus. Modbus is basically a set of instructions sent across two physical wires; one for sending and one for receiving.
    Those two wires need to be plugged into the kit somewhere. Some bits of tech (my Ecodan ASHP, for example) require that you buy an extra little adapter that plugs into the box and then presents somewhere to plug the wires in. Other boxes like my inverter already come ready for the wires to be plugged in. Sometimes you’re required to attach the cables by inserting into holes and tightening a screw (a bit like wiring a 3-pin plug) whilst other times you may have a ready-made socket. Only your documentation will tell you which it is, but in my case Growatt provide a socket (that it has labelled as an RS485 port) that accepts an RJ45 plug (the same as you get on the end of a physical network cable). As a result, my first step iss to plug a network cable into that socket.
    In the case of Growatt, I then have to follow some of the documentation to tell that RS485 port to operate in something called VPP mode. What’s that? No idea, but since the port was empty there is little to be lost in changing its mode.
    Next, I need to connect the other end of the network cable to something and I have a choice to make. Either I can connect it to a serial or USB port on my Home Assistant server or I can connect it to a little box that sits on my home computer network. There is no right answer, but I have chosen the latter since that allows me to connect to the little networked modbus box from any of my computers at home, meaning I can troubleshoot from a familiar computer even at the same time that Home Assistant is talking to it. Some others on this forum will disagree with that choice and prefer the serial port route, but I haven’t personally tried it. Nonetheless, my particular choice of clever little box is called an RS485 to Ethernet converter and the one I’ve settled on is from WaveShare.
    Bear in mind that even though a network cable such as I have used actually has eight wires in it, modbus only uses two of them and in any case the WaveShare box doesn’t have an RJ45 socket to plug the modbus cable into; it only has one of those sockets for plugging into the network. As a result, I now have to snip off the unattached end of the modbus cable plugged into the inverter, identifying wires 4 (blue) and 5 (blue/white) and attaching them to terminals RS485B and RS485A respectively on the WaveShare device.
    Next is to configure the WaveShare box as a computer network device. WaveShare’s wiki is pretty reasonable here but it is still a bit of network configuring; you’ll know how confident you are or not with doing that once you’ve read their instructions. It involves downloading and installing a bit of software called VirCom so that, once the WaveShare box is on the network, you can find it, give it a network address (not mandatory but highly recommended so it doesn’t later change), set a password (once again not mandatory but highly recommended) and change a couple of settings if needed. Specifically for the Growatt inverter, I need to ensure the baud rate (the speed instructions can be sent across the wires) is brought down to 9600 and I need to make sure the transfer protocol is set to “Modbus TCP to RTU”.
    Modbus is a tinkerer’s paradise so there’s lots to get confused about. However, at this point my inverter should be accessible on the network and ready for Home Assistant to start using.
    Thanks for publishing this
    As another concrete example of what home assistant can achieve, in the last two weeks I ran it up on a raspberry pi and have created a simple automation to switch my electric car charger ('granny' - ie 10A) on/off according to the 'excess' output from my solar panels.
    The only hardware involved was a raspberry pi (which I had already) and a Shelley 16A relay - the latter about £15.  Fortunately my smart meter already has an interface accessible to HA, so I didn't even need an energy meter.
    The automation plays quite nicely with my existing solar diverter and does something that, realistically, I cant do myself.  So its not simply a time saver, its a genuine benefit.  Basically, during the summer months, I can plug in the car without worrying what else is on, and get at worst half price charging when the excess power is available.
    If I didn't have a pretty good export tariff already, the charging would be essentially free.  Result as far as I am concerned.
    3
    My pleasure, @jamespa; glad you liked it.
    Eventually, my aim was not so much to show what Home Assistant can do but to give an illustration of how incorporating one of the several home automation systems can be achieved with relatively little technical knowledge (albeit with quite a bit of time invested, nonetheless) and how the real benefits come from getting disparate things working together in a cohesive and unified way. What you've outlined illustrates that very well; you have a solar array and an electric car and your home automation system gets the two interacting via some logic neither of the component parts has individually. Thus the whole becomes greater than the sum of its parts.
    I have no idea how far down the Home Assistant route you've gone already over and above what you've described but I've found every time you add another element to it the array of choices of how to gain benefits increases manifold. It would be great to hear what you've done and are planning so we can compare notes.
    (@batpred)
    As eventually I got my Seplos BMS firmware upgraded, I am now embarking in the next stage of optimising my hybrid inverter+battery setup. I moved my HA to near the Solis inverter, to keep the standard operating mode simple.
    At the moment, I ticked the box on the app that says "use Solis AI" and I am watching what it learns and does.
    But as I am also looking to get the G99 process completed for 5Kw export, I am curious what I may need to ask for so my (export ready) smart meter can use this interface accessible to HA, @jamespa ? I am laying an extra ethernet cable to future proof the setup anyway.
    And @majordennisbloodnok , thank you for the very comprehensive overview of using home assistant for energy efficiency. 🙂
    This post was modified 12 months ago by Mars
    Posted by: @batpred
    Ah, this is a bit of a mess.  The interface from the smart meter to HA depends on the HID (home interface device - the little display you get).  Some HIDs are supported, some aren't, and you are unlikely to get a choice.
    I have a GeoHome HID for which there is an integration interface in HA, albeit a little bit flaky because its cloud based.  I do use it to capture my gas consumption (I still have a gas hob) but not my electric which I capture with a shelly device - no cloud needed.  Shelley devices are cheap, well built and reliable.
    I don't think the smart meter interface itself is accessible to consumers, so its not just a HA problem, its a feature (I think) of the underlying smart meter specification.  @transparent will doubtless correct me if I'm wrong.
    Posted by: @batpred
    If I were building a house today I would probably run an ethernet cable to every room, brought together in a central location.
    That said modern wifi is pretty good if you place the access point suitably, and HomePlug seems to work quite well.  A friend of mine has run an ethernet cable from his router to the consumer unit, in order that the head end of his Homeplug system can be as near as possible to the CU, and thus comms over it needs only to do one 'hop'.  That makes a lot of sense.
    I remember some of my colleagues back in the 80s working on the basic technology that has now become Homeplug, and also the basic technology for what BT now calls 'full fibre'. The technology underpinning homeplug was once seen as a way for electricity utilities to offer internet, but that never took off, I think because the topology of the distribution network doesnt work well for this purpose and so the signal/noise budgets didnt work out.
    This post was modified 12 months ago 4 times by JamesPa
    Posted by: @batpred
    I suppose now is a good time to ask what you’re trying to achieve, @batpred; why you actually want your smart meter to read HA data and how you would expect it to make use of the information.
    Bear in mind too that:
    • your inverter will be able to tell you how much has been imported and exported just as well as - if not better than - the smart meter. I’m not talking accuracy; just granularity of times.
    • the SMETS2 specification expects devices to interact with the smart meter rather than the other way round.
    • the smart meter data isn’t just held by the energy supplier; it’s also held by the DCC and you can pick up the data from there via various means. The one I use for HA is the Hildebrand integration. The only limitation here is that the data is only available a day behind since it’s not collected from the smart meter more than once a day.
    In short, I can’t see a benefit to trying to have your smart meter read your HA data, so I’d be interested if I’ve missed something.
    Posted by: @batpred
    Couldn’t agree more, although I’d say more than just one cable per room. Structured cabling makes things so much more stable and reliable that if the opportunity arises then it makes sense to treat it like electrical sockets; install double network sockets wherever you think you might want them.
    Wifi is good these days but sadly often misunderstood, hence the typical problems.
    Firstly, because of the way ethernet works, ethernet over wifi is effectively a party line shared by all devices attached to it. That means some really fast wifi can very quickly become dog slow simply because there are too many devices attached to it. Wired ethernet gets round this because of the way a switch works; effectively every port on a switch becomes a separate ethernet network and so only ever has two devices on it. A marked simplification but a good illustration nonetheless.
    Secondly, mesh wifi setups are great for giving better wifi coverage but each hop still adds chatter and therefore slows things down. If you can manage it, a far more robust solution is to install wifi access points (as @jamespa suggests) with each AP connected to the switch by an ethernet cable (and likely powered over it too, using PoE) or, of course, through the earlier mentioned structured cabling. At that point, the effective wifi network speed is dictated more by the number of devices attached to that specific AP.
    This post was modified 12 months ago by Majordennisbloodnok
    (@batpred)
    Posted by: @batpred
    Ahem, my original post could have been more precise... I reworded it a bit.
    Essentially I have a smart meter. I am not sure if it is export ready and mainly wanted to understand if it will need replacing. And also how I could check if the current or future could provide data to HA.
    I am looking for data less than a day old, as I realised some of the integrations I have only provide that.
    I missed the "Octopus Home mini bus" that allowed tapping into consumption and export locally...
    I would have done that, but concrete floor stopped any ideas..
    Firstly, because of the way ethernet works, ethernet over wifi is effectively a party line shared by all devices attached to it. That means some really fast wifi can very quickly become dog slow simply because there are too many devices attached to it. ...
    Agreed that wifi has become much more reliable and faster specially in low density settings. Even if I doubt any of these inverter to HA etc connections need much bandwidth.. The last issue I came across of bandwidth limitation was an old driver.
    For streaming, etc wifi 6 or 802.11ax is "fixing" the issue that you mentioned. It effectively allows directed traffic between two wifi 6 devices using the same RF channel, and this is adjusted dynamically. So another two similar devices can share it. It can also allow one hub to double the bandwidth of the same channel, if it is "beaming" two clients sufficiently apart.
    Anyway, I always thought that it is IP over wifi, as in the OSI model.
    This post was modified 12 months ago 2 times by Batpred
    Posted by: @batpred
    I thought I has answered this; I think the answer is NO because of the bits in italics.
    (@batpred)
    @jamespa
    I may use some of the CT clamps I already have. Still it seemed the "home mini" would open up more options. My HA is a lab, when I properly retire, I may play a bit more with it.
    You did answer it. I was just replying to major's post about wanting a smart meter to read HA data - not even dreamt of any use case around it..
    This post was modified 12 months ago by Batpred
    Posted by: @batpred
    Posted by: @batpred
    No problem, @batpred. If I misunderstood then at least it gives us the chance to discuss in a bit more detail what others may also be interested in.
    Eventually, the IHD queries the smart meter via zigbee, so there are plenty of third party solutions (and probably DIY ones too) that make use of that. Hildebrand, for instance, sell a box that can be installed in your home which then effectively acts as a zigbee to MQTT bridge so you can get smart meter data every 10 seconds or so.
    This still doesn’t answer the question, though, about why your inverter’s import/export figures aren’t good enough and therefore warrant the realtime connwction to the smart meter. I hasten to add that “because I want to” is still a valid answer, of course.
    Posted by: @batpred
    No argument at all about the bandwidth between HA and the devices’ wifi adapters being very low. Speed is not an issue. However, wifi dropouts are not uncommon whereas they are pretty much unheard of on a wired connection - and more secure, too.
    You’re right, too, that wifi 6 handles the broadcast spectrum better and therefore mitigates the “shared” nature of wifi. I wouldn’t say it fixes the issue, though although it may do so to all intents and purposes in a domestic setting. Crowded environments such as airports will nonetheless still hit wifi 6’s limits and suffer performance degradation, but here we’re moving into realms that don’t really matter to a homeowner unless they’ve got a Victorian sized family, each loaded up with all the IT gadgets they can handle.
    As for your point about IP, you’re confusing OSI layers. TCP/IP is a network protocol (i.e. a communications “language” the devices are talking in) whereas ethernet is a set of rules that define how the network itself behaves. You mentioned the wifi standard of 802.11ax (wifi 6) which defines how an acces point handles connections to wireless devices. Ethernet is the 802.3 standard and defines a particular way devices can communicate over physical wired networks. If you want to be precise, TCP/IP operates at layers 3 and 4 whilst ethernet covers layers 1 and 2, hence why you can see IP operating on an ethernet network.
    Absolutely strictly, though, I haven’t helped by conflating ethernet and wifi. A device will talk over an 802.11 network (wifi) with the access point which then talks ocer an 802.3 network (ethernet) to the switch. What it’s talking on top of that network infrastructure will be IP data packets.
    Apologies, I'd missed that earlier post.
    James is correct. Consumers cannot directly contact the Communications Hub box of a Smart Meter.
    The Comms Hub has a Secure Zigbee channel which operates the Home Area Network (HAN).
    The HAN is used by your In Home Device (and gas meter if you have one).
    The IHD may be one which also has a WiFi channel, but most haven't.
    Octopus have released a Home Mini, which replaces an IHD and allows you to interrogate it via their App.
    But even if you have such a unit, it is restricted to delivering an approved set of data under a SEC licence.
    It won't allow you to access the entire set of data in your Smart Meter.
    If you wish to retrieve other data from your Smart Meter, then you need to become a Member (shareholder) in the Smart Energy Code Company, SECCo.
    SEC members can design devices and apply to have them authorised.
    The process includes a number of security checks which take place over several months.
    That device accreditation is chargeable, and will cost £7k upwards.
    Devices and the companies which own them must be re-approved every year.
    This post was modified 12 months ago 3 times by Transparent
    (@batpred)
    Of course, so let's get that clarity others will find useful.
    Posted by: @batpred
    This is still a good reference model. When (inter)networking started being implemented and deployed, I can confirm the OSI model was very useful.
    So ethernet and wifi protocols are both covering layer 1+2 - the physical side and the low level protocol handshaking between the components that connect to the "network", be is bus, p2p or whatever.
    IP fits layer 3. TCP may fit layers 3+4
    As @transparent mentioned, someone's pointing their IA model to learn from fora like this. So it is important to be transparent.
    With all due respect, there is no need to make new definitions for these simple terms.
    TCP/IP is a set of protocols that broadly fits into layers 2-4s.
    ethernet covers a set of protocols that map to layers 1-2.
    In that we agree, it was not necessary.
    And in that situation where a device talks to multiple layer 1+2 combinations, the network components in that device are enabling it to act as a bridge or a router. Simple, if you imagine that each of the hops between network components has its own stack of OSI layers.. I think that OSI link I put explains it all.
    A Home Assistant box with all its connections is usually a gateway in that OSI terminology, that spans layers 1-4.
    Page 1 / 2
