Adventures in heat loss calculations
Posted by: @susannasaundersPosted by: @toodles@rob-of-york In my experience, energy used to supply DHW will be higher in the colder months - have you estimated and made any allowance for this factor? Toodles.
Agreed because the ground water is colder and will require more heating to provide showers etc... In summer the ground temperature is around +10C whereas in winter its much closer to +3C. Maybe nearer zero in some instances. But as the central heating is also running, I don't see how to estimate this increased power draw needed to warm the water an additional 7 to 10C degrees during winter? Unless I guess you just double it during the winter months and maybe 1.5 times for the shoulder months? Any thoughts on this?
I think you may be overthinking this. It really is most unlikely matter, unless its for pure interest or you have really high usage.
But if you do want to work out the power needed then its easy from basic physics:
energy required = specific heat capacity X mass X temperature rise.
Since 1l of water weights 1kg, all you need to do is estimate your daily volume of (hot) water used and multiply it by 4200 (the specific heat capacity of water in J/kgC) and then again by the (extra) temperature rise needed. This gives energy required in joules.
1kWh is 3,600,000 J, so you can get energy in the more familiar unit kWh by dividing by this number. Then divide by 24 to get average power required in kW.
So for example if you use 150l of DHW a day and the winter time additional temp uplift needed is 7C then the additional energy is 150*4200*7= 4, 410,000 J which is 1.225 kWh or an average (over a day) of a little over 0.05kW.
In other words (with these figures) you can ignore it completely when sizing your heat pump!
@toodles thanks! So as suspected, around a doubling of the cost for DHW during winter! 👍🫶
Installed solar [7.44 kWp] and batteries [Sigenstor 3 x 8kWh] and 12 kW inverter in July 2025.
Currently viewing this topic 3 guests.
Recently viewed by users: Rob of York 35 minutes ago, JamesPa 27 minutes ago, Toodles 56 minutes ago, Majordennisbloodnok 1 hour ago, SusannaSaunders 21 minutes ago.
- 2,813 Topics
- 66.6 K Posts
- 5,437 Online
- 7,223 Members
@rob-of-york The Panasonic units also have a microscopi...
By Toodles , 1 minute ago
Posted by: @jamespa My personal view is that we have...
By Rob of York , 25 minutes ago
By SusannaSaunders , 36 minutes ago
By Mars , 1 hour ago
By Toodles , 7 hours ago
I didn't throw it away. Is there a way to determine wha...
By bobflux , 9 hours ago
By bontwoody , 1 day ago
By Rob of York , 1 day ago
I think you're right! 🤨
By Chilli304 , 4 days ago
By Rob of York , 5 days ago
