Why don't people ch...
Why don't people choose heat pumps?
11 Users
17 Reactions
Posted by: @toodles
@jamespa Our Panasonic A2A system is due to be installed in late January or February and I know that has humidity control. Toodles.
Thanks, I would expect most of the big names to have this, just not so sure about the bargain basement devices.
(@rob-of-york)
@susannasaunders
The high end Daikin Ururu Sarara A2A units do heating, cooling, humidification, and de-humidification. The humidification is done by extracting moisture from the outside air and using that, so no tank to fill etc. It also does "humid heating" so that the relative humidity does not fall as the room temperature is increased.
The simpler Perfera A2A unit that I have does heating, cooling, and de-humidification. The latter, called "dry mode" doesn't change the room temperature but extracts moisture.
During cooling on hot humid days the change in temperature can mean that the A2A dumps quite a lot of water outside. On the most hot and humid days this summer, it was removing something like 0.5 to 1 litre of water per hour. This happens continuously because of the gradual air exchange between the outside and the inside of the house, with warm moist air creeping back in. The A2A itself does not exchange any air between outside and inside, since there are only refrigerant and power lines running through the wall, along with a small condensate pipe.
On cooling air flows over the cold evaporator coil and this causes water to condense out - so it is continually extracting some water from the air. I have not noticed this cause any issues with dry air (we have LCD battery powered temperature and humidity sensors in every room). In this respect, it is probably best to run the A2A in auto mode, so that it turns the fan up and then down as needed, doing the minimum necessary to reach the set point.
Because there is no air exchange as such with single-split or multi-split A2A, on heating the relative humidity naturally decreases in just the same way that it would if the room was heated via radiators.
Daikin A2A units also have something they call "flash streamer", which uses high speed electrons from plasma discharge to breakdown fungal mold, pollen and other allergens as well as bacteria and viruses in the air that passes through the unit.
@rob-of-york The Panasonic units also have a microscopic filtration system built in by the way. Be aware that the Daikin Ururu units have to be connected to a dedicated external unit each. I was considering them as a possible candidate until I found out this was the case! Regards, Toodles.
Page 5 / 5
