Posted by: @transparentSo, based on that observation, we'd need to know a lot more about the 'tables that you've found online',
what experimentation was done to create them, and who is publishing them.
I'm pretty sure I noticed they are not all the same, even with the same (LiFePO4) chemistry and conditions. I am sure there is a definitive table, but which one? That's why (along with the other things like it has to be a resting voltage) I decided not to use voltage as my primary way of determining SoC.
You can not accurately determine state-of-charge of a LiFePO4 battery by voltage, with the exception of the so-called 'knees', that is, where the battery is near 100% (3.45V and above) or near empty (towards 2.5V). Everywhere else the voltage curve, no matter the state of charge, is essentially flat. The only reasonably reliable way to track state of charge over the entire range is to do Coulomb counting (using a shunt).
My blog where I write about all the systems in place and decisions made for my off-grid house at 63 degrees north in Finland.
Posted by: @upnorthandpersonalEverywhere else the voltage curve, no matter the state of charge, is essentially flat.
Indeed. Another nail in the voltage-for-SoC coffin.
Posted by: @batpredClearly one for @transparent but is your BMS Seplos? I would not expect much help from Solis.
Was Fogstar aware you were going to use a Solis? If so, are they not helping?
I bought a pre built battery and don't know which BMS it has. I did ask them if the battery would be compatible with the inverter before I ordered the battery but I haven't contacted them, I thought I would get a better answer here, which I am getting.
Posted by: @batpredPerhaps at some point we have someone with a battery from the compatibility list that can get an answer from Solis
The Fogstar battery I bought has the option to use several different protocols. It was on the plyontech protocol when it arrived and the solar installer set the inverter to work with that. It was very straightforward, especially as the solar installer was interested to see a Fogstar battery and wanted to connect it up. There is a data cable between them and the inverter reads the SOC from the battery, I've no idea what other data they exchange as it has been seamless so far.
Posted by: @transparentBut an SoC of 13% is reasonable for cell voltages around 3.1v
Thank you, it is good to know that the figures do in fact line up. The tables I found on line were on various battery suppliers website and although there was some difference between them I printed off a couple that seemed to be the most common figures I was finding. It wasn't at all scientific, I was trying to get an idea of how low would be sensible go. It would be interesting to hear what others do.
There is also a screen showing capacity, full and remaining capacity in Ah and that seems to match to the SOC%, although I guess they could all be calulated from one reading.
I've driven EV's since 2017 and try to take reasonable care of the battery so am aware of not leaving the battery at high or low SOC's but I do use them to their full potential at times and fully charge and discharge the battery on occasions where it is useful to do so. I work on the assumption that something else will make the car uneconomical to repair before the battery becomes degraded enough to cause an issue.
I'd like to treat the home battery the same so am trying to understand if discharging to 3.05-3.1V most nights is a good idea or not.
I have just read on the Fogstar website that the current battery 8000 cycle claim is with a 91% depth of discharge at 25° and 50A charge and discharge rate. I had alreay set the charge rate at 50A as that is more than enough to fully charge the battery in the 6 hour Octopus IOG cheap rate window. The sheet doesn't specify where the 9% margin should be but there's a warning light on the battery if it gets below 10% so that would seem like the place they would like it to stop discharging.
Posted by: @johnnybI've driven EV's since 2017 and try to take reasonable care of the battery so am aware of not leaving the battery at high or low SOC's but I do use them to their full potential at times and fully charge and discharge the battery on occasions where it is useful to do so. I work on the assumption that something else will make the car uneconomical to repair before the battery becomes degraded enough to cause an issue.
LiFePO4 (LFP) does not mind going to 100% and 0% state of charge. In practice, stay below 3.55V per cell at the top, and say 3.0V at the bottom. There is no capacity beyond those points. You don't have to go with the 80-20 'rule', that's for different chemistries such as NMC in a typical EV. Just don't keep the cell at a high voltage, they have to be allowed to settle.
There is a reason Tesla for example in their LFP vehicles recommends charging to 100% frequently: it's the only place where the balancer can work (you have to be in the knee of the curve in order to use voltage to determine which cells to balance), and the state of charge can be reset. Measuring a '90% state of charge' is practically impossible unless you have a very accurate coulomb measurement, and even then...
With LFP, even if you have 'only' 4000 cycles (the 8000 number typically puts the cut off at 70% remaining capacity, 4000 cycles makes that 80% of original capacity remaining) - if you do a full cycle every day, you have a life span of almost eleven years. Calendar aging will destroy them likely faster.
The one thing that kills LFP is temperature. Keep them at their optimal, 25C. Charging at 40C will half the cycle life.
Posted by: @upnorthandpersonalIn practice, stay below 3.55V per cell at the top, and say 3.0V at the bottom.
So voltage is a reasonable way to determine what is too high and too low even if there is a small window inbetween?
Posted by: @johnnybSo voltage is a reasonable way to determine what is too high and too low even if there is a small window inbetween?
Check the image below for a typical charge/discharge curve at different rates for LFP. The 'middle' part is, for all intents and purposes, flat - you can not be accurate to measure that voltage, and it also depends on the charge/discharge rate. In addition, even at rest, it would just be 'more flat'.
In the knees of the curve however, you can see that small changes in state of charge lead to large voltage deltas. This is where voltage can be used to indicate state of charge (at least, you know you're 'almost full' or 'almost empty') but you still can't say for sure you're at '93%'. What you can say with certainty at this stage is that some cells are running ahead, and others are lagging - so the balancer knows what to do.
Note however that with this chemistry, you could get to 99.9% state of charge at 3.45V, when you allow the cell to absorb at that point (keeping the voltage at 3.45V and wait for the current to taper off). In other words, the only thing you can know is that above 3.45V you're pretty much full, but this could be in the high 80's or 99.9%, and you can't say for sure.
Posted by: @johnnybI bought a pre built battery and don't know which BMS it has. I did ask them if the battery would be compatible with the inverter before I ordered the battery but I haven't contacted them, I thought I would get a better answer here, which I am getting.
I have a similar setup and know it has a seplos bms since I had to upgrade. If you look to add storage, you will need to know. This is as they need to be the same type - the inverter just connects to one that manages the others.
I had some odd situation with data about the battery not being shown on soliscloud. The troubleshooting highlighted the Solis team is overwhelmed and easily find excuses, particularly around compatibility and installation. So this can become a pain. And what Fogstar may have said is (at best) irrelevant to them. 🙂
Hopefully you have a different bms type, one that will be officially tested.
Anyway, as you see, there are plenty of people here with experience that are in the same boat..
Yes.
And I generally agree with @upnorthandpersonal on this issue.
Here's a discharge curve which I've previously posted to this forum:
Let me point out that it's the Amps being transferred which causes the fluctuations we tend to see reported by an inverter, or by the App connected to a BMS.
My batteries have a relatively massive storage capacity (56kWh) which means the current tends to be very much lower than the system is specified to handle. It's rare that a battery would be charged or discharged at any more than ¼ of the current for which the BMS unit and cabling are rated. In these circumstances the voltages I see on the various connected meters are pretty stable.
Over the years I've learned enough about the way the batteries behave to know their SoC in the middle of the discharge curve just by noting the voltage.
But I also have a 5.5kWh battery set which I take to exhibitions and seminars.
That behaves quite differently. The current being drawn has a much larger effect on the voltages I read on the BMS App. I can't use my experiences with the larger battery set to tell me much about the SoC of the small one!
This is what my seplos is showing along the day. The readings are direct from the BMS.
So as expected, there are significant drops in voltage during discharge. Voltage recovers quickly after it stops discharging.
The soc is shown as Wh of this 16kWh battery.
The temperature increases significantly when charging, even if this is limited to max 100Amps. How many cycles could I expect from the 8,000 the battery could deliver?
From your numbers (if I read them correctly, the graph is a bit small):
- You stop charging at 55V. If this is a 16s pack (which it should be) that means you stop at 3.437 V per cell. You also don't absorb there. This means that you won't charge to 100%, and your balancer can't do its job. You will lose capacity over time because of this (but you can recover this with balancing).
- Your temperature hits 30C. That's about the upper limit I ever use for my cells. Is there inadequate cooling? Are you sure this is cell temperature and not BMS temperature? If it's the BMS, you're fine. I highly doubt it's cell temperature actually: cells have a large thermal mass, and it takes quite long to heat 16 cells from 20C to 30C. There should be more than one temperature sensor in most batteries like this.
- The voltage drop is normal. Cells settle at 3.375V on their own. You're at 3.23V per cell under load. Especially since you're not fully charged, I consider this ok for now.
Personally, I would fully charge the pack (say, 3.5V to 3.55V per cell, 56V to 56.8V pack voltage). Can you monitor individual cells? Once you reach this voltage, you really want to check for cell imbalance (and also cell protection, maybe you won't reach this voltage at all because the BMS goes in protection when one cell goes too high). It would also be nice to be able to monitor the balancer. If you can't get to this voltage in one go, you definitely have an imbalance in which case you should gradually increase the voltage so the balancer can fix this without the BMS going in protection.
- 2,539 Topics
- 59.1 K Posts
- 401 Online
- 6,818 Members
By JamesPa , 3 hours ago
By JamesPa , 4 hours ago
By Boycey , 6 hours ago
By ChandyKris , 7 hours ago
By JamesPa , 9 hours ago
By Papahuhu , 9 hours ago
By TechnoGeek , 10 hours ago
By Gruff2001 , 13 hours ago
By Papahuhu , 13 hours ago
By antonical , 15 hours ago
By Mars , 15 hours ago
By JamesPa , 16 hours ago
By RobS , 1 day ago
By antonical , 1 day ago
By Boycey , 1 day ago
By Judith , 2 days ago
By antonical , 2 days ago
