Outdoor Battery Solutions?
VAT Notice 708/6.
It's not as far as I am aware ever mentioned MCS and indeed many of the things it covers are simply not even MCS covered in the first place (eg draught strips).
For a vat registered operation the paperwork should be no more than usual for VAT. For a not vat rated operation I don't know but I doubt it's fun if it's even possible.
Thank you. From what I see, it covers all building trades. VAT registered contractors or subcontractors can supply and install items in the list free of VAT.
Have you modelled the costs of switching tariff?
We have solar, battery and ASHP. Like you, our peak winter usage can approach 50kWh per day. We are able to cover this with a single Tesla PW3 battery at 13.5kWh (installed outdoors in the rain) by using the Octopus Cosy tariff which has 3 cheap rate charging slots.
The Cosy cheap rate is more than your current EV tariff, but we need a fraction of the battery capacity as we are able to recharge the battery 3 times per day so each recharge only needs to last 6h until the next available cheap rate slot. It also works well ion summer as a single 13.5kWh PW3 nicely covers a full day's usage (~12kWh) in summer, even if there is absolutely zero solar. We do not have an EV in that mix.
So for us the question was/is simple - would the cost of additional batteries be offset by moving to a cheaper overnight tariff (we could pretend we have an EV on regular Octopus Go). To achieve that, we'd need two or three PW3's so for us the smaller (cheaper) battery capacity works out better and gets us to the point of having zero bills (export in summer offsets import in winter)
There is also the risk that you may not see a return on capital if cheap overnight EV tariffs end (or prices normalise) as you now have large battery capacity that you can no longer cheaply fill.
For us, adding a 16kwh battery means a heatpump can reduce energy costs by 50% (instead of a 10% drop(. And since our £/kwh is significantly lower than Tesla's, it is a simple decision.
- 2,815 Topics
- 2,542 Online
- 7,230 Members
Below most suspended ground floors definitely matters u...
By EtchedPixels , 9 minutes ago
Sorry, gents, I wasn't supposed to drop a comment and t...
By Pirate Rich , 12 minutes ago
@brazilguy67, glad you've managed to get someone to hav...
By Mars , 1 hour ago
We've had an influx of new members joining the forums o...
By Mars , 2 hours ago
By Chilli304 , 4 hours ago
By JanHarley , 5 hours ago
By JamesPa , 8 hours ago
By bobflux , 21 hours ago
By bontwoody , 3 days ago
