Reliable, easy to use home battery options
I have just had a my inverter and battery installed, about a week ago, and I think it is very similar to @batpred system. I have a Solis S6-EH3P10K02-NV-YD-L with 16.1kWh Fogstar battery pack. I have a seperate CU for 'back up load' which the inverter switches over to run from the battery if there is a power cut. It isn't full islanding, I don't have everything running through this board, but it is enough to keep the lights and some of the sockets powered in the event of a power cut. We rarely have power cuts and they don't last for long so that wasn't a big consideration, but as the inverter has the option and it is a new build I have made use of it. If I really want to I think the invert is just about large enough to run the house but I was advised not to run everything through this board. The electrician has set it up so it is fairly easy to move circuits between boards if I want to change things in the future. This was all installed as part of the solar install so I don't know an exact cost but the inverter, battery and extra wiring has cost around £4-4.5k. This is a 10kW 3 phase inverter and it was picked as it works with 48V batteries, so not the cheapest option. Most 8/10kW 3ph inverters only work with high voltage batteries and I couldn't find those at a price I was prepared to pay. I expect the battery to pay for itself within 5 years, but time will tell. With 2 EV's we can use everything we can store during the summer months so with that and being able to run mostly from the battery during the day I expect a lot lower electric bill.
I think the inverter will run without internet connection but I haven't tried it yet. It does have an AI powered setting in the app that will set the charge and discharge times according to the house needs, weather forecast and tariff, including Agile. This does need an internet connection. I used it the first night but that was it as I have been trying out different settings myself first. I like to play around with the settings to start with to find out how it works but after that I'm hoping the AI will keep things ticking over without much involvment from me.
In terms of safety the latest Fogstar Solar batteries have integrated fire suppression built in them so a lot of people must be asking about the fire risk. I bought the batteries in the black Friday sale, just before they put the latest batteries with fire supression on the website. I bought Fogstar because of the price compared to most other batteries. If it doesn't last quite as long then that is OK. From everything I have read LiFePO is very unlikely to have an issue with runaway so I am comfortable with them in the house.
All the charge and discharge rates, times etc. are controlled by the inverter. The battery pack feeds the SOC back to the inverter and the inverter uses that to stop the charge when the set SOC is reached. The battery pack has a screen with a few basic settings and the SOC and cell voltages. I like having the cell voltages as I can see that the SOC% and the cell voltages on the battery display don't match the charts I can find online showing LiFePO4 cell voltages and SOC. Fogstar are being careful with the readings and protecting the battery, both low and high. It also displays state of health, which I would love to have on my EV batteries!
I am finding that with a new build house and a 5kW heat pump we have been able to run all day from the battery charged overnight for most of the last week, but we don't use too much energy to heat the house.
Recently viewed by users: JohnnyB 31 seconds ago, trebor12345 48 minutes ago, Batpred 50 minutes ago.
- 2,418 Topics
- 54.8 K Posts
- 213 Online
- 6,098 Members
Is it normal to use power from the grid when running off the battery?
I've recently had a Solis hybrid inverter fitted, with ...
By JohnnyB , 36 minutes ago
@jamespa having read through this thread I will add a f...
By JohnnyB , 1 hour ago
RE: Reliable, easy to use home battery options
I have just had a my inverter and battery installed, ab...
By JohnnyB , 2 hours ago
RE: Ecodan Pump Issues… Circulation pump turns off when heat pump compressor turns off
@patch321 Ok fair enough with the heat loss (if a 2024 ...
By ASHP-BOBBA , 2 hours ago
Our system is radiators, large ones and now with DIY fa...
By RobS , 4 hours ago
RE: Samsung E101 Error Message and my ASHP Efficiency
@johnnyb amazing that the our forum is serving its purp...
By Mars , 4 hours ago
Best option for controller upgrade? - Grant Aerona
Fairly new heat pump owner - Grant Aerona 3 10kw - and ...
By Topher , 5 hours ago
RE: How to use my Hanchu battery storage for home without it feeding back into the grid?
@countryman-helmsley Is the Hanchu ESS app definitely ...
By SKD , 5 hours ago
RE: Installer Fitted 9kW Instead of 11kW Heat Pump and Changed MCS Paperwork - What do I do?
@jamespa thank you. I think I'll go for 59 at -8, we ca...
By MairiA , 6 hours ago
RE: Daikin Wireless Thermostat
@toodles Yes. British Gas seems to have done an exce...
By Bash , 6 hours ago
RE: Is my Samsung gen6 outside air temp sensor missing a sheath/sleeve?
@papahuhu Mine is similar. Is your house not getting...
By bontwoody , 8 hours ago
Just a brief update to keep things transparent. Secti...
By DREI , 9 hours ago
RE: Ideal HP290 14kW ASHP - how to optimise
Sorry forgot about the three choices. It’s the 2nd one ...
By Davesoa , 9 hours ago
I continue to receive emails from homeowners sharing he...
By Mars , 10 hours ago
RE: Water outage in the the south-east
We think alike @editor ! All those bottles (and I expec...
By Toodles , 10 hours ago
@mrfield, welcome to the forums. Please go here and ...
By Mars , 12 hours ago
I did not hear back from the tech team. (Assume they ar...
By swwils , 14 hours ago
In the Home Assistant firmware the data points...
By F1p , 1 day ago
RE: GSHP WOES! Midland based engineer recommendations?
@johnbroome if it is not the pressure in the expansion ...
By ASHP-BOBBA , 1 day ago
So I hear the export MPAN that UKPN assigned should be ...
