@jeff You seem to have a grasp of all things regulatory, so what's you view....should we be keeping an eye on what our European neighbours are doing and upgrading our gas network in harmony to theirs? Re: EU regulation 2024/1789 and in particular hydrogen blending (support upto 2%) on european gas networks. This seems to be legislation whose impact we surely cannot totally ignore?
Posted by: @transparentThere are two 'hydrogen to the home' projects occurring in the Yorkshire gas supply area.
A Blended hydrogen trial is occurring in Gateshead with 600+ homers involved.
2% blend sounds exactly what may allow to avoid too much insurance issues and liability but to divert/delay the "transition"! A scam with an aura of legitimacy?
16kWh Seplos Fogstar battery; 8kW Solis S6-EH1P8K-L-PLUS hybrid inverter; Ohme Home Pro EV charger; 100Amp head, HA lab on mini PC
Posted by: @iaackRe: EU regulation 2024/1789 and in particular hydrogen blending (support upto 2%) on european gas networks.
Is this to accept some kind of "contamination", like in case methane pipework is occasionally used to transport hydrogen for the dwindling needs of some industrial processes?
This is part of the aims of the regulation
(5) |
This Regulation aims to facilitate the penetration of renewable gas and low-carbon gas and hydrogen into the energy system, enabling a shift away from fossil gas, and to allow renewable gas and low-carbon gas and hydrogen to play an important role in achieving the Union’s 2030 climate objectives and climate-neutrality by 2050. This Regulation also aims to set up a regulatory framework which enables and incentivises all market participants to shift away from fossil gas and plan their activities to avoid lock-in effects and aims to ensure a gradual and timely phase-out of fossil gas, in particular, in all relevant industrial sectors and for heating purposes. |
Posted by: @iaackThis is part of the aims of the regulation
(5)
I can hear those screeching tyres... the end of Russian gas, desperate measures required...
Plus their industrial policies have been genuinely planning to mop up excess wind electricity and produce hydrogen. Without significant domestic fossil fuel players and a typical tight regulatory framework, they may stick to a straight and narrow path.
I saw there's a UK consultation to formally accept the alignment.
@batpred my understanding is the current limit for hydrogen within the natural gas network in GB is 0.1% by volume, as set out under the Gas Safety (Management) Regulations 1996 (GS(M)R). If gas blended with hydrogen >0.1% reaches an interconnector it could not currently be accepted by GB. In this scenario the interconnector would temporarily cease activity until such time as the available gas came back into quality requirements of the GS(M)R.
Yes, I think this is why this consultation is under way https://www.gov.uk/government/consultations/hydrogen-blending-into-the-gb-gas-transmission-network/hydrogen-blending-into-the-gb-gas-transmission-network-consultation-document
Hopefully there's no lobby pushing to keep it as is..
Posted by: @diverted-energy... there is nowhere near enough Surplus electricity to replace the UK volume of Gas as i said earlier.
We need it for EVs and your beloved Heat Pumps over generation of Hydrogen.
As for Portsmouth, it is the worst possible place to produce Hydrogen due to the whole South Coast being in a desert of Renewables.
That's understandable...
but I was referring to our 'other' naval base at Plymouth 😎
It's the home base for the Royal Marines, one of the few sections of our defence forces which can be mobilised independently, without also requiring other regiments to provide logistics, catering etc.
The Marines are a good choice for trialing hybrid warfare, using new technology incorporating drones and autonomous vehicles.
The UK is learning fast from what's happening in Ukraine.
Plymouth is within the area of the electricity grid where there is substantial excess generation.
That will continue to be the case for another decade.
Unlike the south coast further to the east, the use of electrolysis to produce green hydrogen at Plymouth is a perfectly sensible use of energy which would otherwise be discarded.
I do have exact figures for the (lack of) 'reverse power' capacity which affects the 400kV Grid Supply Points in Cornwall and Devon.
But they're on a part of the National Grid data library which isn't publicly accessible.
What I probably can tell you is that one of those GSPs currently has 60% more connected generation in winter than its available capacity, and a queue of accepted generation which will take it to 513% over-supply.
Another GSP has 22% more winter generation than its capacity rating, and a connection queue which will raise that to 414% over-supply.
Surplus generation is yet higher in summer.
The area coloured brown on the above map attained an annual excess of supply over demand in Spring'23.
There is no shortage of electrical power in the area, but prices are higher than in London.
It seems the end of cfd payments is in sight, even if a few years away...
Does anyone have a current graphic, visual or breakdown of all the stuff that's loaded into an electricity tariff (post autumn budget announcement)?
Posted by: @editorDoes anyone have a current graphic, visual or breakdown of all the stuff that's loaded into an electricity tariff (post autumn budget announcement)?
Ben Watts posted on LinkedIn that he had updated this web page to reflect the budget
https://www.electricitybills.uk I can’t see a lot of difference in the 2030 projected cost though!
As electricity prices continue to rise and specialist heat pump tariffs disappear, many homeowners are discovering that heat pump efficiency isn’t optional… it’s survival.
In this video, I break down:
- Why bad heat pump systems are being financially exposed
- Why Time-of-Use tariffs aren’t a safety net
- What happens when an energy company kills a tariff overnight
- And what homeowners must demand before installing a heat pump
- 2,418 Topics
- 54.8 K Posts
- 339 Online
- 6,098 Members
RE: How to use my Hanchu battery storage for home without it feeding back into the grid?
@countryman-helmsley In that case is there a button ...
By IRMartini , 1 minute ago
RE: Heat pump not reaching flow temperature
@jamespa @johnd just spoken with our installer who also...
By DaveC , 20 minutes ago
Thanks. Thats pretty much my intended route i...
By JamesPa , 59 minutes ago
RE: Is it normal to use power from the grid when running off the battery?
The Solis S6 has various modes of use. I currently have...
By Batpred , 1 hour ago
RE: Is my Samsung gen6 outside air temp sensor missing a sheath/sleeve?
@papahuhu I would definitely check the upstairs radiato...
By bontwoody , 1 hour ago
RE: R290 and Foundation Air Bricks
I appreciate that the risk is probably proportionate to...
By L8Again , 2 hours ago
RE: Ideal HP290 14kW ASHP - how to optimise
Great. It’s not bad is it, though I agree it may repres...
By Davesoa , 2 hours ago
RE: Water outage in the the south-east
1: There are homes at the Lizard peninsula, SW Cornwall...
By Transparent , 2 hours ago
RE: Ecodan Pump Issues… Circulation pump turns off when heat pump compressor turns off
@f1p apologies, you are absolutely correct
By Patch321 , 2 hours ago
Area under graph is indeed a valid approach and the one...
By JamesPa , 2 hours ago
RE: Reliable, easy to use home battery options
However, see what I've just posted here about these (ch...
By Transparent , 3 hours ago
RE: Installer Fitted 9kW Instead of 11kW Heat Pump and Changed MCS Paperwork - What do I do?
Another good bout of cold weather should test whether t...
By JamesPa , 5 hours ago
RE: Samsung E101 Error Message and my ASHP Efficiency
@johnnyb amazing that the our forum is serving its purp...
By Mars , 16 hours ago
Best option for controller upgrade? - Grant Aerona
Fairly new heat pump owner - Grant Aerona 3 10kw - and ...
By Topher , 17 hours ago
RE: Daikin Wireless Thermostat
@toodles Yes. British Gas seems to have done an exce...
By Bash , 18 hours ago
Just a brief update to keep things transparent. Secti...
By DREI , 21 hours ago
I continue to receive emails from homeowners sharing he...
By Mars , 22 hours ago
@mrfield, welcome to the forums. Please go here and ...
I did not hear back from the tech team. (Assume they ar...
By swwils , 1 day ago
In the Home Assistant firmware the data points...
