UK electricity price predictions and price cap discussion
61 Users
894 Reactions
699.4 K Views
Your energy: 109 kWh
Posted by: @old_scientist
the supplier [...] can receive extra payments for grid balancing (or whatever), and the consumer because the supplier shares some of that financial benefit in exchange for use of the equipment.
As a consumer, we have no way of knowing how much (more) the supplier is making, and whether the split is fair.
I think it is possible to assess whether the Suppliers and consumers are each getting a fair share.
Certain payments originate from NESO, rather than the TNOs and DNOs. These include:
  • balancing services
  • reactive power support
  • system inertia support
Balancing Services already has an entry-point on the NESO Data Portal.
NESO is the Independent System Operator (under the terms of the 2023 Energy Act). They are committed to transparency, and should be able to provide data on request.
It dismays me to see members of the public issuing FoI Requests to NESO. That shouldn't be necessary. Transparency includes such non-confidential information by default.
If we can't find something on their Data Portal, then email the generic 'customer address'. You receive a Reference Number, and the staff will forward your requests to the relevant department.
If we think something isn't presented well on the Data Portal, then email the Data Products Team.
This post was modified 4 months ago by Transparent
(@papahuhu)
Your energy: 4 kWh
@old_scientist
There is a degree of nuance to the calculation. Remember that you are using a PW3 that has a unique unlimited cycle warranty in the marketplace. If I were using one of the other “smart” batteries, where the warranty is limited to 5-6k cycles I would be thinking twice about how I used my battery. As it happens I, semi-intentionally, flog mine to death  (I cycle 3x in 24 hrs) knowing that it is almost certain to require warranty replacement before 10 years.
(@etchedpixels)
Your energy: 62 kWh
What I was keen to say before - and it bears repeating - is that any criticisms I have of third parties controlling my kit are criticisms specific to me and my setup. If an intelligent tariff works for you, you should make use of it, which, of course, you are doing. The only cautionary note I would want to sound is that decisions like that should be made with eyes wide open precisely because of the difficulty in judging how equitable the arrangement is.
Agreed - there's a place for everything from "Dunno, I rent a box and my bill is lower" to "I'm in control send me pricing hints".
The problem with "intelligent" tariffs that involve a user element is that there are a lot of users and they will systematically game any tariff. Even tariffs which are "we give you a plug in box, magic happens and you get some off your bill" are going to get gamed.
The more people game a tariff the more complicated the rules get, the less people can understand it and thus the more "normal" people move off it. The IOG slow charging game is just a taster of where this tends to end up in systems (the UK tax system being the finest example globally of where you end up). We've already now got people smart charging in the day and switching over to granny charging at night. Likewise the Octopus "can switch tariff" stuff led as far as a home assistant module that just before midnight worked out the best tariff from the days Octopus Mini data and switched (because the switch covered the day you switched too).
People will go to a lot of trouble to automate scraping pounds off their bill, and for some it's really about the game not whether it's worth it, but they then share the trick with everyone else.
(@majordennisbloodnok)
Mitsubishi Electric
Your energy: 47 kWh
Posted by: @etchedpixels
Very much so, @etchedpixels, but I'd also add a couple of points.
Firstly, that "gaming" of a tariff doesn't just apply to customers; it can apply to the provider too, hence my point about the need for an element of trust. We've seen with companies like Aira and Homely an attitude of "you don't need to know what's going on underneath; just leave the fancy stuff to us" when dealing with heat pumps, leading to suspicion of them marking their own homework. No reason to think a typical energy provider would think any differently, and it's only the open and freely available data from Octopus that allows us to do at least some of the homework-marking ourselves.
Secondly, "gaming the system" is a very emotive term that implies misuse. However, by "playing the game" with the Octopus Agile tariff, I'm not only saving money I'm also interacting with the tariff in exactly the way Octopus want, so "gaming" the tariff is actually a good thing for both parties. That obviously doesn't mean that all ways of programmatically interacting with the energy supplier are necessarily desirable but let's not make too many assumptions about what's "right" or "wrong" (not to suggest you are making those assumptions, btw).
(@etchedpixels)
Your energy: 62 kWh
My background is systems so I am using the systems definition here of "gaming the system", that is manipulating the properties and inputs of the system in order to obtain your desired but not intended by design result. No judgement involved - to start with you can't judge any kind of gaming of a system as good or bad generically because it depends upon the observer. Like I suspect the fact lots of people on Go don't own an electric car and are at some level "gaming the system" is something Octopus are choosing not to worry about.
Mitsubishi Electric
Your energy: 47 kWh
I'm very much grounded in systems too, so I think we're viewing things in the same way. However, I'm well aware many terms have an implied meaning well beyond their logical definition; let's face it, "good" and "bad" are easily understood words with as many implied meanings as people doing the implying.
I do wonder, though, whether we can make any safe assumptions about what results are or are not "intended by design" in the context of these tariffs. You mention about Go being marketed for EV users and that Octopus are choosing not to worry about people without EVs adopting the tariff, but I'd argue Octopus are probably well aware enough about this as to include non-EV users in their actual tariff design. I might, of course, be wrong.
(@batpred)
Your energy: 31 kWh
Not many people consume overnight, so as a principle it is a safe bet…
Probably the reason Octopus does not bother if Go users have an EV.
Posted by: @batpred
For how long do you think that will be the case?
1: The electricity generation mix at night is different. There's no solar, but there's considerably more from gas-turbine plants.
Because NESO have been given the remit to decarbonise the grid, they will want to reduce CCGT-sourced electricity to zero.
That will raise prices, making overnight tariff slots less attractive.
2. Charging an EV will typically take double the kWh of the household demand.
As EV ownership increases, overnight supply becomes a problem.
Hinkley-C and Sizewell aren't large enough to plug the hole.
3: Data Centres are expected to require as much electricity as GB, and they work right through the night.
NESO report that data centre demand connections are around 50GW.
The days of cheap-rate overnight are coming to an end.
(@etchedpixels)
Your energy: 62 kWh
2. As EV ownershp increases it'll certainly increase demand but most electric cars don't travel far in a day. It's electric trucking that is really going to matter not cars. Trucks use more kWh, operate on much more intensive schedules are much more constrained on charging time schedules. I'm not entirely sure I believe either will get finished without EDF going under or similar.
3. The AI game is Enron mark 2, passing money in circles, booking it repeatedly and praying that trump bails them out, as already seems to be happening with oracle. Fortunately we are blessed with expensive electricity which is acting rather well as a parasite repellant. Plus thanks to Trump there's no longer enough helium to run the chip fabs indefinitely either.
This post was modified 4 months ago by EtchedPixels
(@batpred)
Your energy: 31 kWh
Posted by: @rob-of-york
Rather, the weather in the UK is highly dependent across one part of the country to another. It is easily possible under high pressure conditions to get very little wind generation from a very large number of wind generators all at the same time. We can see this unfortunate reality in the recorded outputs. See https://www.energydashboard.co.uk/historical for the 90 day period starting 1st Oct 2025 and look at the total solar and wind output for Oct 12th to 17th 2025.
This topic seems more suitable for this thread...
I agree with the above, this is clear and particularly in the first few weeks of the year are very likely to result in shortages.
To address that, the 400KV network allows power generated elsewhere in the continent to be routed. In particular from nuclear, that is unlikely to be as constrained as it was during long spells of dry weather (I hear causing price hikes across Europe).
It is not impossible to develop technology to address the supply issues caused by this type of weather pattern; however, it is expensive to do so. Demand response is not a comprehensive answer over this time frame, for example reducing the state of charge of EV batteries in the evening to smooth out peak demand is achievable and starting to happen provided that they are charged again over night, but doing the same over a 3-4 day period before recharging is perhaps a stretch. Building sufficient pumped hydro or compressed gas systems to handle this type of supply issue is expensive and the number of sites suitable for the former is limited in the UK.
Trying to be autonomous on electricity production has a significant cost (and delay, based on past history). But it is arguably unnecessary.
Jeff
 Jeff
(@jeff)
Your energy: 2 kWh
I wasnt sure where to post
https://committees.parliament.uk/event/28505/formal-meeting-oral-evidence-session/
An interesting meeting today where there were discussions on the current major issues with long duration and ultra long duration storage.
A moan from the sector that there is a complete lack of cost recognition in the  capacity market for longer duration storage, hence we have ended up with lots of short duration BESS storage where it is easy to make a profit. A waffling response from the minister... but i dont think even he believed what he was saying.
Also a pause on next years CfD round to reform it. Been picked up by some of the media. Should have been much bigger reforms before this... to get better aligment between production/transmission/distribution/ storage/usage. But at least a stronger recognition we cant simply keep building large amounts of generating capacity at any cost with no where for it to go. Builds on the shift from Burnham and Healey to try and get costs under control now Miliband is out of the way.
I find the committee meetings quite enlightening about what the government is thinking, warts and all, and gives an insight into their level of knowledge.
This post was modified 4 weeks ago 2 times by Jeff
(@batpred)
Your energy: 31 kWh
great session
Reminds me why some politicians can be hated. The cheek of the two that, when they could use their allocated time to ask sensible questions, just finish their “representations” with: “I had a new boiler fit at home recently and so can the gov find a good reason to keep the gas pipework in use?”
This post was modified 3 weeks ago by Batpred
Page 139 / 141
