Unvented Hot Water ...
Unvented Hot Water cyclinder 300l 50c vs 60c
2 Users
0 Reactions
(@jeegnesh)
Topic starter   [#2168]
I have an 300l unvented cyclinder which I'm currently heating to 52c during cheap rate and then topping up at midday.
Probably 5 showers plus taps and kitchen sink usage.
My query is if I was to heat to 60c would that allow me to not have to top up in the day?
13.6kw Solar, 40kw Battery, 10kw Heat Pump and EV Cars
(@old_scientist)
It might do, try it and see?
As the majority of your usage is showering, where the hot water will be blended down to ~38C, heating it hotter should make it go further as less hot and more cold will be used for each shower.
On a practical note - can your heat pump actually heat the hot water to 60C? Mine can't, the flow temp cuts out at 60C max which achieves a DHW tank temp of ~54C. After this, the immersion kicks in, so hot hot you can heat will depend on the max flow temp your ASHP can achieve.
(@jeegnesh)
I will experiment, yes my ashp is capable of heating to 60c I'm sure I had it that way at the start.
