Solar Yield vs Temperature.
The recent hot spell has taken its’ toll on energy production; though the spec. sheet for a solar panel may well show the percentage loss against elevated temperatures, it really comes home when the sort of temperatures we have been experiencing this last week or so occur. Our 8.1 kWp. array will often produce ~6.4 kW for the core times at this time of year (as indeed it has been doing today with external temperatures in the low 20’s C.). When the sun shines in a clear blue sky but the temperature is hovering at ~ 30 degrees or so C., then the highest output drops to ~ 5.2 kW during those same core hours. Admittedly ten of our 21 panels are ground mounted in the garden and I suspect don’t feel so much breeze as those on the various roofs and thus warm all the more. Should I send a request to the Met Office for full sun from 05:00 - 20:00 but with a cap on the temperature of perhaps 24 degrees C?😉 Regards, Toodles.
A sprinkler may be your best friend, assuming you are far away from the new Kent desert! 😁
Posted by: @toodles@batpred How good are panels at withstanding thermal shock I wonder?
Thermal shock brings back memories of holding the driving wheel while driving back from the Algarvian beaches… 🔥
Nothing remotely close to that experience near that Kent desert.. 😉
I noticed similar during the hot weather.
My south facing 7.2kWp array topped out at around 6.1kW during the very hot weather suggesting ~15% thermal degradation. My panels have a rated thermal coefficient of around 0.3-0.35% per degC above 25C surface temperature, suggesting the panel surface temp maybe as high as 70C (or maybe 60C assuming I have other losses)
- 2,815 Topics
- 2,747 Online
- 7,227 Members
By JamesPa , 1 hour ago
By bobflux , 15 hours ago
By Toodles , 17 hours ago
By bontwoody , 3 days ago
By Rob of York , 3 days ago
I think you're right! 🤨
By cathodeRay , 4 days ago
By Transparent , 5 days ago
