second winter starting with Vaillant 7Kw arotherm plus still noise inside house
just had Vaillant over to service the HP and asked about the humming noise lots of 7Kw owners are experinceing and didnt get much of a response. seems they are still denying a vibration issue with the compressors which transfers through the house via the primaries as a 91hz hum when on HW or when ramping to meet heat demand, which if very cold outside can mean constant hum.
this is a sort of fix but i dont think it should be down to people to have fudges like this added to sort the issue. the compressor needs isolating from the heat exchanger.
Mars do you have any suggestions?
- 2,788 Topics
- 65.8 K Posts
- 2,651 Online
- 7,192 Members
By Singlespeed , 35 minutes ago
just had Vaillant over to service the HP and asked abou...
By AdamK , 1 hour ago
There are of course some installers trying it on, as th...
By JamesPa , 1 hour ago
RE: tepeo ZEB UK Support & Info Thread
OK so ZEB is basically a variant on a storage heater, b...
RE: PV and battery long payback - sense check query
@energystoragetech it's highly improbable that @davidb ...
By Transparent , 1 day ago
@editor I suspect that the Heat Geek online quote is a ...
By AndrewJ , 1 day ago
RE: Adding additional Solar Panels to a DC coupled battery system
Ah, yes. Thanks for clarifying.
@trebor12345 I have been meaning to get home assista...
SunSynk hybrid inverters also have the capability to as...
If you've got a sash window or a door you can remove th...
By EtchedPixels , 2 days ago
Roughly how most air/air is done except that step 3 doe...
RE: Nook batteries from Octopus
@batpred If your energy use is low enough that just get...
I suspect 4 yrs ago, their approach had not got to this...
Also don't forget that in you may not be able to use th...
