Nook batteries from...
Nook batteries from Octopus
9 Users
7 Reactions
sonosppp
(@sonosppp)
Both of octopus' new batteries are Fox ESS units re-badged. Their specs are widely available.
(@batpred)
Posted by: @etchedpixels
According to multiple sources these are FoxESS batteries with an Octopus sticker on them.
just wondering if anyone has got any Nook to confirm what it is exactly and what it works like?
Do they come with a ct clamp?
Are they pre approved by the dno?
(@energystoragetech)
New Member Member
Until Octopus publishes the electrical limits, the key distinction is energy capacity versus usable power.
A 10 kWh stack limited to around 800 W export can still shift cheap-rate energy, but it will not behave like a conventional whole-home backup system. I would want confirmed figures for continuous and peak charge/discharge, EPS or islanding capability, compatibility with existing inverters, and whether the smart controls require an Octopus tariff.
This post was modified 1 month ago by Mars
(@batpred)
@energystoragetech
Yes, and 800W would be too low for the kettle..  But when DIY is here, it may be an acceptable limitation.
(@etchedpixels)
@batpred If your energy use is low enough that just getting a Fogstar and a suitable 48v inverter isn't more financially sensible I suspect likewise that 800W for most things will be fine. It'll not cover the kettle, microwave, induction hob/oven or any direct water heating but it'll do most stuff.
The so called "plug in ready" kit with wifi CT clamps does spectacularly bad with induction cookers anyway as they tend to switch on/off full power very rapidly and the clamp is permanently way behind reality.
Page 2 / 2
