Removing a Low Loss Header from Samsung Gen6 System
also its worth saying, the PWM pump is not the enabler to run at low flow temps. That comes from having big enough emitters, properly balanced, etc.
what the PWM does is control the flow rate up/down to maintain the DT , at lower output levels when running in a steady state for a long period. For a given lower output, you can have either the flow rate staying the same (Fixed speed pump) and DT reduced, or the DT can stay the same and the flow rate reduces (variable speed pump).
there is an FSV , can't remember the number of the top of my head, for Target DT. with a PWM pump in the system, the samsung will vary the flow rate to try to maintain this DT but only when its in the stable part of a heating cycle. It has no effect when doing DHW, or when in the initial startup part of a heating cycle (Which is 30-60 mins , at least on my system). This FSV for DT control method has no function if you don't have a PWM pump (this is a common misconception), and is of little use in a system with primary/secondary seperation.
@iancalderbank Thanks for that explanation Ian, very interesting and useful
10kWh DC coupled battery
@iancalderbank Ah okay, thats interesting. I have to say deciphering the user manual and FSV values is one of the most difficult parts of owning a samsung heat pump.
Samsung Gen6 8kw ASHP in a two bed victorian mid terrace.
@ecobaker You should see a Mitsubishi! 🤣
- 2,774 Topics
- 65.4 K Posts
- 1,839 Online
- 7,177 Members
@jamespa thanks. im not used to being on a forum where...
By mrkfm , 3 minutes ago
@jamespa Thanks. this is very helpful. It's actually t...
By mrkfm , 1 hour ago
Is there any expected time frame for an update to be ab...
By Singlespeed , 3 hours ago
Posted by: @springswood I confess to becoming a litt...
By Rob of York , 4 hours ago
Analysis of the economics of switching to an A2W ASHP compared to other heat sources
This post aims to analyse the economics of installing, ...
By Rob of York , 8 hours ago
@editor does that mean you have to have two separate ex...
By mrkfm , 23 hours ago
Posted by: @ian-s Could always use the money saved o...
By Rob of York , 1 day ago
Depends on what controls the pump! Thats the whole poi...
@renewables345 I would say if it a new build it’s no mo...
By Aventus Eco , 3 days ago
