Ideal Logic ASHP - change from 55°C to 35°C Heating?
Ok on second thoughts scrub the questions. Id be tempted to optimise the rads as previously described. If you find that this results in a rad curve lower than 0.8 (IE the rads can run at a lower temp than the ufh), assess what to do with the ufh. If there is scope to run it at lower ft do so otherwise this will be the limiting factor. It would be quite unusual however for rads to be sized so they need a lower ft than ufh.
Agree - I will finish optimising the rads before I think about the UFH
UFH temperature is adjusted with the mixing valve located on the manifold. It's currently set at 50°C which is the max setting but can be dialled down if needed. The speed of the pump can also be tweaked to increase or decrease the flow rate. The flow meters can also be adjusted for each loop if needed but fully open up when the UFH is on.
I've now opened the rad TRV's to max and will monitor the heating performance over the coming days.
UFH should never be at 50C since small feet can get burned. I think the regs say 39(?). But your floor covering could be damaged too unless it’s tile or concrete. Nobody want pipe shaped marks on their wood or blown adhesive on LVT.
Good point. I’ll keep my eye on the manifold temperature gauge which is currently showing 30C with the room temperature currently at 19C. After changing the heat curve yesterday from 1.5 to 1.3 the heating flow temperature has reduced from 50C to 45C. I’m not sure the UFH would ever reach the same temperature as the flow but best to keep my eye on it to prevent the issues you have mentioned. Thanks for your help. It’s great to learn from others, especially through forums like this one
- 2,763 Topics
- 65 K Posts
- 2,671 Online
- 7,169 Members
RE: Vaillant Aurotherm - Heater Wire Position
Batpred I was trying to establish where the heater elle...
By trebor12345 , 5 minutes ago
Posted by: @jamespa At this point its probably worth...
By Rob of York , 25 minutes ago
@batpred thanks for getting a copy. Appreciate the supp...
By Mars , 10 hours ago
We have a 6.56kW solar PV system (16x 410W panels) inst...
By Rob of York , 15 hours ago
RE: Where heat loss surveys seem to go against practical reality
@cathoderay @jamespa I've managed to get some nice re...
By Rob of York , 2 days ago
RE: 7kW EV Charger Options Advice
Doh, not sure that I was thinking straight there, less ...
By Rusty , 2 days ago
I’m really liking reading through this thread and the r...
By Judith , 2 days ago
Thank you @trebor12345
By rgabor , 2 days ago
Panasonic Free Multi Z and Etherea Internal units.
My prospective installers have suggested the Panasonic ...
Great. You just need to find a way of cranking up your...
We had two heat pumps installed without Govt funding. H...
By Rob of York , 3 days ago
My Adapt is finally installed and running! Almost a yea...
By tomasmcguinness , 3 days ago
Thanks, @batpred. That integration is the one I have in...
